Gen Vi Front Seal >
Gen Vi Front Seal
Gen Vi Front Seal
Old 01-12-2008 | 08:29 AM
fastlane40's Avatar
Default Gen Vi Front Seal
Can you buy the front timing cover crankshaft seal as a part and if so what's it called?I have heard with the Gen VI you must buy the timing cover as a part including the seal.Thanks
fastlane40 is offline
Old 01-12-2008 | 09:22 AM
Smitty's Avatar
You can get it from your local Chevy or GMC dealers parts dept. Just ask for a Gen 6 frt crank seal. It way cheaper than buying one from Merc.
Smitty is offline
Old 01-12-2008 | 02:51 PM
fastlane40's Avatar
Many had trouble with this seal leaking?
Old 01-12-2008 | 04:54 PM
Strip Poker 388's Avatar
Rob
I have heard any trouble with them. ck you harmonic balancer seal surface, grooved,rusted,pited? I had a seal leaking on a prop shaft once polished it real smooth made it seal
Strip Poker 388 is offline
Old 01-12-2008 | 05:17 PM
If the balancer is rusted and/or pitted you can put a seal saver on it. It is a real thin sleeve that goes on the balancer. You can get it and the seal from just about any auto parts store. (Auto Zone, Napa etc)
Eddie.
Young Performance is offline
Old 01-12-2008 | 08:28 PM
fastlane40's Avatar
Thanks guys.Got a leak from the front of both.2000 502's.Did the sealing balancer bolt thing.Still leaking.1/4 cup 100 miles.
Old 01-12-2008 | 08:31 PM
fastlane40's Avatar
As you know i'm not "over there"and there is no Chevy parts shop's anywhere.I normally go online to Scroggin dickey but i couldn't find the seals listed as a part.
Old 01-12-2008 | 08:37 PM
fastlane40's Avatar
Default Feedback on this.
Tell me your initial thoughts on this boat.
Old 01-14-2008 | 10:01 AM
Needs more strippers on it!
kennyo is offline
sleeper_dave
1
09-18-2007 09:06 AM
wrenchman
3
05-18-2005 09:15 AM
hustler388
2
02-15-2005 04:11 AM
BadDog
4
07-10-2003 07:07 PM
excaleagle42
1
10-17-2002 11:02 AM
