fuel filter prosharged MPI >
Old 01-12-2008 | 05:51 PM
Default fuel filter prosharged MPI
I had a airmotive 1000 go out within the first 9 months of opperation. Airmotive fixed it and said that my stock water seperator/filter was too fine for the poor suction charterstic of the pump (likes to push more than it likes to suck). They recommended putting the filter after the pump. Any experience out there with this idea? Lots of goodies in this application Merlin heads ect. over 500HP, 5400 RPM, 6PSI, 42# injectors and a custom tune by Dustin. Could I get away with a less fine filter? If I relocate the filter should I put some sort of a filter before the pump?
baronbob is offline
Old 01-13-2008 | 11:47 AM
LAKESIDE RESTORATIONS's Avatar
Lakeside Restorations.com
You would be better off getting a bigger & higher flow separator.. It is better to filter before the pump so that nothing gets into the pump to damage it.. A larger capacity & flow filter should do the trick.. I can get you one if you would like.. Also make sure your lines are big enough as well as having the pump mounted as low as possible if you dont have a feeder pump..
Jamie / Lakeside Restorations
www.LakesideRestorations.com 570-639-2628
We Make Fast Toys Faster, Cool Toys Cooler and Old Toys New!.. Performance, Custom & OEM Parts & much MORE![/CENTER]
LAKESIDE RESTORATIONS is offline
Old 01-14-2008 | 09:55 AM
You Did Not Say What Your Fuel Pick Up Size Was. We See This Problem All The Time, It Causes The Pump To Cavate And Die.
Jb-fse is offline
Thunderstruck
8
03-03-2008 07:14 PM
ippon
2
06-29-2006 07:01 PM
CObarry
12
04-19-2005 03:17 PM
220EagleXp
0
01-19-2003 08:27 AM
