fly wheels
Dear itbs
Keith Eickert performance products can offer you a number of different flywheels but I would need to know a few things first. What generation is the engine? Is it a bellhousing mounted starter or engine block mounted starter? Would you like steel or a aluminum style flywheel? As you can see we have it all here. If you have any questions you can call me at (386)446-0660 or e-mail me at [email protected] .
Tony
Tony
If it's a two piece seal than it is a Gen IV. The only flywheel you can get from GM that is neutral is for the 427That is the only internally balanced big block that GM produced. You can go aftermarket and get a cast iron flywheel from Pioneer.(part # FW100) or a steel one from Hays.(different part numbers for different weights) Hope this helps, Eddie.
Oh, by the way, I sell all of the above flywheels
