Arneson Rocker Plates, anyone using them?
I can't give you any first hand info but I did buy a set to install on my Donzi Blackhawk to put a little hook in the hull. But I sold the boat before I got to install them and sold the rocker plates after.
But, I did talk to a couple people that used them and they had nothing but good things to say about them. They said the boat could run faster in the sloppy/rough water because the rocker plates were part of the running surface as opposed to K-Planes that "drag" in the water. Made sense to me!
I talked to a guy that had them on a smaller boat and he mentioned that they worked really well. You can adjust between giving the boat rocker or adding hook to the bottom. He did say that they required constant adjustment. Hope this helps.
Rocker plates use laminar flow to direct the water rather than a hard anlge like K planes. Plus the flow can be vectored up giving a "rocker" effect.
08 OPA High Points Champion
We had them on our F2 Hustler and they worked very well. Straight line handling was great but tough in the turns as the boat wanted to stay upright. Racing application and recreation use are completely different as most users are not and should not be throwing themselves into turns, especially in heavy traffic, as we did. It also did scrub off a couple of mph as we used a little hook. No chine walk in heavy traffic, drove like it was on rails. Clay
Since rocker plates are mounted flush with the bottom of the hull they become part of the running surface. They adjust in the middle of the plate making them bulge outward(rocker) or inward(hook) to control the attitude of the boat.
Most people want them to add rocker which raises the bow, loosens the boat up and adds speed. My Blackhawk had too much rocker from the factory and I wanted them to add hook for bettr control.
