ls2 heads
Old 01-22-2008 | 05:33 AM
fastlane40's Avatar
Default ls2 heads
Does anybody know what type of valves are used in this motor or better still have access to the head specs?Thanks
fastlane40 is offline
Old 01-22-2008 | 08:53 AM
Are you referring to the LS2 heads on the 6.0l all aluminum GM motor used in vettes/GTOs?
rdoactive is offline
Old 01-22-2008 | 01:42 PM
fastlane40's Avatar
yes.Know what sort of valves are in them?
Old 01-22-2008 | 03:43 PM
rmbuilder's Avatar
MarineKinetics
Fast,
Combustion Chamber Volume: 64.45cc
Intake Port Volume: 210cc
Exhaust Port Volume: 75cc
Intake Valve Diameter: 2.00 inches
Exhaust Valve Diameter: 1.55 inches
Valve Angle 15º
Solid Stem valves
Flow .200"-.600"
Intake Exhaust
136 104
195 135
237 157
260 169
260 180
Bob
rmbuilder is offline
Old 01-22-2008 | 03:47 PM
Amm
If you trust this guy http://www.quicksilvertrucks.com/for...read.php?t=216
Valve Material: Stainless Steel, Hollow Stems, Na filled Exhaust
Amm is offline
Old 01-22-2008 | 03:59 PM
rmbuilder's Avatar
MarineKinetics
The LS1/LS6/LS3 heads have the hollow/sodium filled valves. The LS2 heads use an 8mm solid valve on both sides.
Old 01-23-2008 | 05:52 AM
fastlane40's Avatar
Thanks Guys and great to hear from you again Bob.Trust all is well.
Carl.
Old 01-23-2008 | 08:21 AM
Ed
Default LS Series Valves
The LS6 & LS3 had/have the hollow stem sodiums, the LS1 did not. The LS6 & LS2 heads are extremely simular castings, the only difference being the sodium valving in the LS6 heads, with "yellow" valve springs, which simply denotes seat pressure.
Ed is offline
Old 01-23-2008 | 02:55 PM
bor's Avatar
bor
if youre looking for a power upgrade better can take the L92 truck version head used on the ls 2 blocks and complet l92 truck engine they have bigger valves(stainless steel) and better flow!
2.16" Intake Valve
1.59" Exhaust Valve
70cc Combustion Chamber
260cc Intake Runner Volume
90cc Exhaust Port Volume
Flow Data:
Lift, Inches Intake Flow @ 28" Water
With 4.125" Bore
Exhaust Flow @ 28" Water
With 4.125" Bore
.100 79.2 57.8
.200 153 114.4
.300 225 147.2
.400 276 170.3
.500 309.6 183.1
.550 323.2 186
.600 332.2 189.5
.650 327.7 191.1
.700 330 192.6
.750 317 195
.800 317 195.8
lots of corvette or pontiac gto owners buy these heads as a low cost ($450 These heads are sold complete with valves, valve stem seals, keepers & retainers.) powerupgrade
I am building a ls 2 engine whit this heads in to a 21ft phantom
bor is offline
Old 01-23-2008 | 03:15 PM
2.16" Intake Valve
1.59" Exhaust Valve
Flow Data:
With 4.125" Bore
With 4.125" Bore
.100 79.2 57.8
.200 153 114.4
.300 225 147.2
.400 276 170.3
.500 309.6 183.1
.550 323.2 186
.600 332.2 189.5
.650 327.7 191.1
.700 330 192.6
.750 317 195
.800 317 195.8
Very true but I believe a L92 head would be too much for a stock cube 346 LS1 with their big 260cc intake runner. The AFR 205 head with its 205cc port can support power well past
7K rpms with the right combo. I would use the L92s on larger bore motors like a 383 or 402 or bigger.
Ryan00TJ is offline
