Shining up discolored drive??? >
Old 01-27-2008 | 02:09 PM
East Coast B's Avatar
My drives have a slight cloudy discoloration to them. I tried to use hull cleaner then polishing compound and still discolored.
What's the secret to getting rid of the cloudy look of them?
East Coast B is offline
Old 01-27-2008 | 06:11 PM
Mine too.
formula 382 sr-1 is offline
Old 01-27-2008 | 06:51 PM
Are you running drive showers? If not that could be some of the cause. Dirve gets hot when running.
Noise Pollution is offline
Old 01-27-2008 | 07:02 PM
Yes Eddie Marine showers and amsoil gear lube in the drives changed every 20 hrs.
Old 01-27-2008 | 07:06 PM
try toilet bowl cleaner... The Works toilet bowl cleaner to be speific
fountainguy214 is offline
Old 01-27-2008 | 07:09 PM
Tried it still looks like $!#% . I use the works to get hull stains off .
Old 01-27-2008 | 07:33 PM
I do the same for the hull...
Looks like those drives are gonna need a repaint
Old 01-27-2008 | 07:36 PM
Yup it looks like new paint. Where can I find new decals for a Bravo 1.
Old 01-27-2008 | 08:00 PM
Thunderstruck's Avatar
Temp fix squirt WD40 on them. Sometimes will help.
Medium term solution I taped up everything including the transom and the decals, scuffed the dull paint with 400 grit and spray painted with the can Merc Phantom Black. Looks fine.
Long time cult member.
Thunderstruck is offline
Old 01-27-2008 | 08:10 PM
Thats what I use now to make them look good. it looks like new paint.
