Go Back  Offshoreonly.com > Offshoreonly Marketplace > New Products and Member Discounts
High Performance Electronic Fuel Level Senders >
Old 01-29-2008 | 12:27 PM
Default High Performance Electronic Fuel Level Senders
This could quite possibly be the last fuel level sender you ever install!! No more moving parts to fail.
Of the many uncertainties that a boater faces often the largest is the accuracy of his fuel gauge. The fuel sending unit's in a majority of production boats today use a simple float style design that in some instances, provides limited accuracy due to fuel slosh and the up and down bouncing of marine power boating If you have or are experiencing the symptoms we've got the answer for you, this double tube design measures the amount of air trapped between the tubes to accurately and precisely measure your current fuel load This design makes installation and calibration for use with 33-240 ohm gauges.
NOTE: 12" sender can only be trimmed to a minimum of 6". A shorter unit to as shallow as 3" can be special ordered for an additional fee.
Hardin Marine is offline
Old 01-29-2008 | 02:23 PM
FYI:
As with most our products you can view the installaition instructions on our website.
Click here for the online instructions for the Fuel Level Sender
BillR
Cigarette
11
06-01-2009 10:14 AM
OSO News
Offshoreonly Industry News
0
12-05-2007 03:14 PM
Elite Marine
12
11-21-2006 12:53 AM
38KV
3
01-06-2005 09:39 AM
