Bravo Three 28 P vs Bravo Three XR >
Old 01-30-2008 | 04:17 AM
Default Bravo Three 28 P vs Bravo Three XR
We are looking for some Bravo three xr props instead of the normal Bravo Three 26 P we are using now. Can anybody tell me what the ride pitch is for the XR?
Thanks in advance!
We are using a Formula 271 FT 496HO Bravo Three X 1.81:1 26P blades.
Boat is running good on these props.
Sorry I mean 26P!!
waaldingo is offline
Old 01-30-2008 | 07:40 AM
Knot 4 Me's Avatar
You would most likely go to a 27" Bravo III XR propset.
Knot 4 Me is offline
Old 01-30-2008 | 01:01 PM
So a 25 Pitsch should be ok...
Waaldingo
Old 01-30-2008 | 01:58 PM
Knot 4 Me's Avatar
Waaldingo
If a 28" standard prop set is correct for you boat then a 25" XR prop set would be too small and you would turn too many RPM's at WOT.
Old 01-30-2008 | 07:55 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile
Go down 1" of pitch when going to the XR props.
i.e. 26 B3's to 25B3XR's.
They come in odd sizes.
Why do you want XR's
[email protected]
bbladesprops is offline
Old 01-31-2008 | 04:19 AM
Because we think the boat will run better with the XR?
Old 01-31-2008 | 07:29 AM
Knot 4 Me's Avatar
You originally stated you were running 28's. So yes, you would want to go to 25's if you are currently running 26's. I talked to Brett at B-Blades about this a year ago and he told me to save my money and stick with the standard propset.
Old 01-31-2008 | 08:23 AM
Smile
If you have cavitation burn problems, the XR props are the way to go. Otherwise the standard props are faster and can be modified to a larger degree.
[email protected]
Dave1972
6
03-30-2009 04:06 PM
1BIGJIM
Drives and Lower Units
3
06-10-2008 12:46 PM
PARADOX
0
02-27-2008 02:31 PM
articfriends
1
07-30-2006 08:10 PM
rslick
13
06-15-2005 11:54 PM
