GPS speedometer antenna options >
Old 01-31-2008 | 06:36 PM
Default GPS speedometer antenna options
I have a AutoMeter GPS speed and I was looking to find a handheld GPS to use for the antenna any ideas of what might work?
MOERON is offline
Old 02-01-2008 | 11:08 AM
Wally's Avatar
Were doomed!
most any hand held that you can configure to have an NMEA output and the appropriate cable to hook it up with "should" work.....i can get my Nextel cell phone to work with a GPS Speedo
-Wally
Wally is offline
Old 02-01-2008 | 11:15 AM
I have a garmin 72 gps and an old nextel !! Show us how !!
z.zuperboat is offline
Old 02-01-2008 | 07:20 PM
rbtnt's Avatar
I've used my Garmin 12XL and currently use a Garmin 76 for my Lavorsi GPS speedo. Two wires between the units and set the handheld for NEMA output.
www.mtboats.com - Pages of boat related links
rbtnt is offline
Old 02-02-2008 | 02:32 PM
Elite Marine's Avatar
If you need an antenna, spliter, etc..., let me know. Livorsi carries these components.
Kirk
Elite Marine is offline
Old 02-04-2008 | 09:01 AM
Thanks for the input !! I just ordered the data/power output cable from Tiger GPS for $21. That savings is going to pay my OSO subscription for years to come !!
Old 02-04-2008 | 09:10 AM
Wally's Avatar
Were doomed!
On my Nextel (I560) when you get to the GPS section in the menu there are 3 options....Position/privacy/ and interface.....when you hit interface you get NEMA OUT on/off....turn it on and you will need a serial data cable for the phone. I had an extra one Nextel sent me with an old phone for some software upgrade.....i cut the cable end off and found the pinouts online....then just hooked the NEMA output of the phone to the GPS and hooked the other wires (batt/ground/ign) as needed for the Speedo headunit and she worked like a charm
-Wally
Wally is offline
Old 02-06-2008 | 09:07 AM
Where did you find the "pinouts online"? I cant find them and to make matters worse I work for Sprint!
MOERON is offline
Old 02-06-2008 | 09:30 AM
Wally's Avatar
Were doomed!
LOL! I used to work for MOtorola and i had problems as well finding things when customers called with R&D Problems! Letmme check to see where i have them...hopeflly i didnt throw it away....i have the cable, so worse case i can get it and hook up a DVM to it...
-Wally
Wally is offline
Old 02-06-2008 | 09:45 AM
Wally's Avatar
Were doomed!
here try this: http://pinouts.ru/CellularPhones-A-N...0_pinout.shtml
many of the older Nextels use the same serial data connectors....oh and be careful...i found out that some of the newer Moto phone have a different serial cable now...i know the i930 takes a special cable that has a toggle switch on it to switch from data to flashing now...dont know how that one would be configured to work on a setup like this hope that helps ya
-Wally
Wally is offline
