Testing a Gaffrig Speedo ? >
Old 02-03-2008 | 08:56 AM
Default Testing a Gaffrig Speedo ?
I would like a quick way to test a Gaffrig speedo.
Seem to remember someone posting a table that
showed PSI to MPH readings. But now I can't find it.
thanks
whatabout1 is offline
Old 02-03-2008 | 10:54 AM
The Menace's Avatar
I shipped mine back to Livorisi. They were more than happy to test the unit. I consider them to be one of the most supportive and user friendly vendors to boaters.
The Menace is offline
Old 02-03-2008 | 12:34 PM
I don't own the boat and was looking for way to tell
work/no-work or if it was anywhere close to actual.
Old 02-03-2008 | 04:49 PM
Mbam's Avatar
Offshoreonly Advertiser
could have sworn I posted this already this am-
MPH = 8.31 * square root(psi)
Mbam is offline
Old 02-04-2008 | 01:22 PM
Hey thanks that is what I was looking for.
So if my math skills are still intact, I come up with the following:
MPH PSI
10 = 1.4
20 = 5.8
30 = 13.0
40 = 23.2
50 = 36.2
60 = 52.1
70 = 70.1
80 = 92.7
90 = 117.3
100 = 144.8
I'm surprized that all of the cheap rubber pitot lines that I see just don't
become balloons.
Old 02-04-2008 | 01:37 PM
MPH PSI
10 = 1.4
20 = 5.8
30 = 13.0
40 = 23.2
50 = 36.2
60 = 52.1
70 = 70.1
80 = 92.7
90 = 117.3
100 = 144.8
become balloons.
I'm not sure about the numbers. On the low end of the scale you should be able to blow on the tube and make the needle move if the psi is that low but I can tell you that I can't do that.
VetteLT193 is offline
Old 02-05-2008 | 11:32 AM
Just went over and tested my friends Gaffrig speedometer.
After I blew about a pint of nasty milkish liguid out of the pitot line. (with an air compressor)
40 PSI showed 60 mph. So off it goes to Gaffrig.
Will be interesting to see what it reads after calibration.
Edit: He pulled the speedometer and about a shot of liguid poored out.
I say replace the tubing.
z.zuperboat
15
11-25-2018 05:10 PM
bearpaw
8
01-26-2007 12:10 PM
JeffGrice
5
08-03-2004 08:03 PM
Ran-Dom 32
04-23-2003 09:01 PM
