MPI #7 fuel rail defect??? >
Old 02-05-2008 | 05:10 PM
Default MPI #7 fuel rail defect???
Read something about this in another thread and could not find anything via SEARCH. Can someone elaborate?
Griswald is offline
Old 02-05-2008 | 07:57 PM
Smitty's Avatar
Check this post out
http://www.offshoreonly.com/forums/s...el+rail+defect
Smitty is offline
Old 02-06-2008 | 07:29 AM
Thanks for the link.
Interesting. So, does anyone know if Merc redesigned the rail in later models? I guess I'll make a date with the end mill and see what we can do with mine.
Griswald is offline
Old 02-06-2008 | 09:30 AM
mjb
I do think that mercruiser fixed the problem sometime after 1997....I think when they went with MEFI 2 but I'm not 100% sure.
I had the best success with mine by using a dremmel tool with a long slender grinding bit. Fairly easy but be VERY careful not to slip and score the o ring mating surface. Make sure you insert the bit into the fuel feed hole before turning the dremel on and turn it off before you withdraw the bit. Thay way you minimize the chance of making a mistake. I found out the hard way! Good luck-
mjb is offline
Old 02-10-2008 | 11:34 AM
Merc does list 2 part #s for the fuel rail.
805405T - not available anymore
861261T1 - is available
Couldn't find anything that said what the difference was though
Griswald is offline
Old 02-11-2008 | 12:28 AM
articfriends's Avatar
I can tell you that the mefi3 fuel rail DOES NOT have the restricted #7 hole,so at least 98 and newer is o/k,not sure if it was just the mefi-1 or if the mefi2 was restricted too,Smitty
articfriends is offline
Old 02-11-2008 | 07:14 AM
Smitty, don't you have an extra MEFI 3 laying around?
Griswald is offline
Rocko C
2
06-22-2008 07:47 AM
vincentblack
2
12-17-2006 02:27 AM
kennyo
4
08-11-2006 03:03 PM
TROUBLE MAKER
13
01-16-2006 06:28 PM
Elite Marine
1
01-05-2003 10:40 PM
