Raw Water Pump >
Raw Water Pump
Raw Water Pump
Old 02-06-2008 | 12:07 AM
Default Raw Water Pump
At speed does the raw water pump do anything?I am going to install relief valves and am trying to figure out if I should install them before or after the pump.It would be great to install them at the sea strainer which seems like they would work because the water is at pressure as soon as it enters the boat but does the pressure increase because of the pump at speed.Thanks
JJONES is offline
Old 02-06-2008 | 12:25 AM
1CE
Most pressure relief set ups are installed @ the sea strainer because @ high speed press. can become excessive, what is your water press. @ WOT anyways ?
1CE is offline
Old 02-06-2008 | 12:41 AM
At idle or threw the harbor its roughly 5 psi but when on plain 35 to 40 psi or more!I plan on installing relief at the strainer.Does this sound good?
JJONES is offline
Old 02-06-2008 | 06:01 AM
fastlane40's Avatar
I think if installed before the pump you would have issues with the pump sucking air at lower speeds.I thought all reliefs were after the pump for that reason.
fastlane40 is offline
Old 02-06-2008 | 09:29 AM
MM1
Drill relief holes in your thermostat and you won't have to plumb in anything else to your boat.
MM1 is offline
Old 02-08-2008 | 01:45 AM
1CE
Default 35-40
merc. marine likes 30-35 lbs. max. your on the high side put your pressure relief in the strainer. The pump can't suck air the blow off valve it is set in the closed position and only opens when the set relief pressure is exceeded. good luck, J ps the idea here is to prevent excessive water press. which could blow intake manifold or head gaskets etc.
1CE is offline
Old 02-10-2008 | 10:29 PM
Thanks 1ce,THat was the plan,just wanted to make sure.
JJONES is offline
Old 02-11-2008 | 05:20 AM
fastlane40's Avatar
Sorry Jonesy i was thinking bleed off instead of valve.
Old 02-17-2008 | 03:34 PM
1CE
correction news report update from MERC. likes 25-30 psi max.
1CE is offline
Old 02-17-2008 | 04:03 PM
Can the Merc raw water pump (at 5K plus rpm of the motor) exceed the 25-30 psi to the motor? If so, does the merc racing relief valve be better installed between the pump and the motor? That way the motor is completely protected from any spike in water pressure?
ROTAX454 is offline
jdub
7
03-26-2007 05:06 PM
CHAOS REIGNS
1
06-20-2005 10:10 AM
StrikinLightnin
5
08-15-2002 09:04 PM
SR-24
4
04-01-2002 07:48 PM
SR-24
03-31-2002 07:51 PM
