Manifold/riser compatibility between manufacturers? >
Old 02-06-2008 | 10:06 AM
Default Manifold/riser compatibility between manufacturers?
I've got a set of RM manifolds & risers but I need a 3" spacer. The RMs are dry joint so could I use the OEM Merc spacers that I already have. Other than headers and proprietary designs like Stainless Marine, are most other aftermarket manifolds & risers cross-compatible?
handfulz28 is offline
Old 02-06-2008 | 11:54 AM
Almost nothing is compatible between exhaust manufacturers. I don't know if the merc spacers will fit with Rev marine stuff. I doubt it.
Griff is offline
Old 02-06-2008 | 12:01 PM
BY U BOY's Avatar
I have been wondering the same thing.
I have a set of marine power manifolds and am under the understanding that th EMI are a copy of these. Can anyone tell me otherwise. I would like to get so SS risers.
Sory didn't mean to hijack....I will delete if you want me too.
BY U BOY is offline
Old 02-06-2008 | 02:42 PM
BuB, no need to delete, all info is welcome.
So if nothing is compatible, that means that you always have to go back to the manufacturer of the exhaust for gaskets? Cuz I'm thinking that would be an easy way to see what is compatible...manifold to riser gaskets.
Old 02-06-2008 | 02:58 PM
CPPerformance's Avatar
Gil marine, Mercury Hi-performance, and Power torque manifolds share the same gaskets. Imco is it's own, Stainless Marine is it's own. And many of the early EMI, Rev, Kodiac, and a couple of others are from the same original OEM manifolds that Kodiac offered. If your not sure you could fax us a copy of your current gasket and we could do some research for you into what exactly you manifold/riser pattern is.
CPPerformance is offline
Old 02-06-2008 | 03:10 PM
BY U BOY's Avatar
When I called EMI they guy could not tell me if it would work or not but he did recommend that i get some of his gaskets and see if they line up.
I have a dry joint.
BY U BOY is offline
Old 02-07-2008 | 10:20 AM
If you find one that fits please post it. I have the Revolution manifolds and need a 1 1/2" spacer between the manifold and riser to get the EX hoses to line up.
Is if acceptable to put a spacer in there?
hdtvned is offline
RMM
3
04-17-2006 07:46 PM
Superboat Guy
3
06-18-2005 08:03 AM
Formula Outlaw
07-02-2004 04:40 PM
Hot Boat
3
05-28-2003 05:35 AM
mxz800
03-28-2003 08:03 AM
