rocker studs >
rocker studs
rocker studs
Old 02-06-2008 | 06:01 PM
Ken N's Avatar
Arrow rocker studs
When changing from stock rocker arms to roller rocker on a BBC does the cocker studs need to be changed as well, for a longer set.
Ken N is offline
Old 02-06-2008 | 06:16 PM
you need to get the rocker studs i think there for 7/16 roller rockers summit or teagues has them.
tony stamis is offline
Old 02-06-2008 | 07:22 PM
Pwrbt33's Avatar
It has to be changed more for the type of material they are made from and the top of the stud is machined flat for the poly locks for the roller rockers. If you use the stock stud the locks will somtimes come loose because they are not flat enough in some cases.
Pwrbt33 is offline
Old 02-07-2008 | 06:02 AM
Vinny P's Avatar
I hate the winter!!
If you have a Gen VI engine, you dont even have studs. You have 3/8" shoulder bolts.
Vinny P is offline
Old 02-07-2008 | 10:47 AM
the studs for the stock heads are 3/8 bottom 7/16top
Old 02-07-2008 | 10:52 AM
Tony, what are you doin????
jeff1000man is offline
Old 02-07-2008 | 05:54 PM
Strip Poker 388's Avatar
Rob
That always had botherd me why they went with 3/8,seems like it would be a weak link?
Strip Poker 388 is offline
Old 02-07-2008 | 05:57 PM
What is the part number for those studs? I never can seem to find them. Good thing I havn't needed many.
Old 02-07-2008 | 07:07 PM
I have two Comp Cam sets for BBC new in packing, $40 per set plus shipping. They are at the shop so I don't have the part # now but will list tomorrow
Andy is offline
Old 02-07-2008 | 10:20 PM
Rob
dont know.mine are still stock chevy ones
