Exhaust
I run EMI Thunder same application I like the Lightning as well but the EMI required less modification to the air intake.
I am a distributor for both as well as lightining. While I do like many of Emi's products as far as the exhaust manifolds the Stainless marine system is really a great product that is hard to beat on many points..
Jamie / Lakeside
Jamie / Lakeside
www.LakesideRestorations.com 570-639-2628
We Make Fast Toys Faster, Cool Toys Cooler and Old Toys New!.. Performance, Custom & OEM Parts & much MORE![/CENTER]
SM has 5 year, that is one reason why I went there! does not matter about Salt Water....Brownie says that if you flush after each use...the life should be lots longer than the warranty period.... my $.02
If they offer XX months then you have some reason to believe that with proper care you should AT LEAST get that out of them because how many builders want hassles of warranty issues?
http://www.cpperformance.com/product...ne-exhaust.htm
http://www.cpperformance.com/product...ng-headers.htm
We have used Lightning's headers for over 5 years... excellent performance, no cracking or rust issues ever. We do however use automatic drain tubes on the headers to drain after every time in the water with no hassles. Besides, the Lightnings look a lot better than the cast units.
Rage
41
02-18-2007 09:42 PM
