Benefits of a superchiller >
Old 02-09-2008 | 04:41 PM
Default Benefits of a superchiller
I have a 27ft Excalibur flatdeck with a supercharged 454. I have heard that a superchiller will benefit me greatly because the bottom half of my motor is still bone stock. My supercharger is a 177 wieand is this a good idea to do or is there other routes I can take to get more horsepower.
puppyray is offline
Old 02-09-2008 | 04:45 PM
Strip Poker 388's Avatar
Rob
how much boost ya at now?
Size 1-71?
Strip Poker 388 is offline
Old 02-09-2008 | 04:50 PM
Right now about 5lbs. and yes it is 1-71 wrong key not very good on a computer
puppyray is offline
Old 02-09-2008 | 06:34 PM
Rob
I did a goggle ,this is the only 1-71 supercharger I found,its on the bike,Maybe its a 177?
also pick of a 3-71 for a v6
http://images.google.com/imgres?imgu...7GGIH%26sa%3DG
either way at 5 psi it will help but not necessary.imo
Attached Thumbnails Benefits of a superchiller-1.71-supercharger.jpeg   Benefits of a superchiller-3supercharger-3-71.jpg
Old 02-09-2008 | 08:26 PM
There are a lot of threads about the mini blowers and chillers on here, search and read. In a nutshell, the benefit of having a chiller is so you can increase boost and not have detonation while running high octane pump gas. I run a chiller with a weiand 177 with the small 2.85 pulley and have no problems. Be aware those little blowers have their limits, but its better than NOT having a blower if thats what you are in to.
Old Navy is offline
Old 02-10-2008 | 06:07 AM
I do beleive that is the same set up that I have. I got the boat from my boss that is also a really good friend of mine. I will ask more details monday mornin and get back. Thanks for the help, Shawn
puppyray is offline
Old 02-10-2008 | 06:10 AM
The boat is also new to me and I've yet to run it in the water but have been on it several times. The set up was ordered new from jegs with a holley carb and dyno tested at 500hp with the stock bottom half just as I have
puppyray is offline
Old 02-21-2008 | 09:08 PM
Are you talking about this one?
http://www.4x4extreme.com.ua/press/supercharger/07.jpg
If so, forget it. It's really not for big boost.
Also, if you want one they aint cheap.
http://www.superchiller.com/pages/products.html
As for your stock bottom end, a chiller helps to make more power by making the incoming air denser. Dense air means you can add more fuel and boost. This will just add more stress to your bottom end.
Hydrophobic guy is offline
Old 02-21-2008 | 09:38 PM
HotPursuit's Avatar
Anytime you can cool the intake charge the egts will come down.This should increase engine life and HP. Less egts the more boost you can run if the bottom end is built for the increased HP. If the blower is at max CFMs it may decrease power because of the extra pressure drop. Good Luck.
HotPursuit is offline
Old 02-22-2008 | 06:42 PM
Thats what I was expecting to spend and was wondering if there is something else I could do before I spent the money for the chiller. What could I get more bang for my buck with. Thanks again for the info guys. And yes hat is the blower I have. 177 weiand with the holley carb.
puppyray is offline
rangerrick63
04-25-2008 05:40 AM
Rebel_Heart
20
09-20-2007 08:15 AM
Fenderjack
Prop Talk
23
09-03-2007 04:45 PM
32fever
09-08-2004 07:55 AM
