Gen 5 502 blocks >
Gen 5 502 blocks
Gen 5 502 blocks
Old 02-10-2008 | 03:42 PM
Registered User
Default Gen 5 502 blocks
Any issues with using these blocks in a moderate performance (650-700 hp) engine? What are the differences between these and the Gen 6?
Chris Sunkin is offline
Old 02-10-2008 | 05:20 PM
ROB FREEMAN's Avatar
i believe the major diff is in the lifter bores , diff timing cover b olt pattern theese are the few that ive herd of
ROB FREEMAN is offline
Old 02-10-2008 | 06:39 PM
Smitty's Avatar
I also think the there is a difference in how the oiling takes place. I think Gen 6 does the crank first, then cam etc.
I have 2 Gen 6 shortblocks for sale. One is a fresh rebuild with 509 ci with SRP pistons and the other one was rebuilt in 2005 and has no issues with 75 hours on it. Both motors made around 750hp.
Smitty is offline
Old 02-11-2008 | 10:36 AM
Chris,
The biggest difference in the two is that the V was not a factory hydraulic roller and the VI is. The V does not have the bosses in the lifter valley to bolt down the spider to hold the lifter dog bones. You must use a retrofit hyd. lifter in a V, whereas the VI's have the GM hyd. lifters. The V has a ten bolt timing cover and the VI has 6 bolts. They use the same oil pan and both have a one piece rear main seal. The heads are also the same. They both accept aftermarket gen IV style heads.
You should have no problem at all with the block in the power level you are shooting for. I am currently building a 540 with a Procharger that should be in the 825 hp neighborhood with a Gen VI block. Let me know if you have any more questions, Eddie.
Young Performance is offline
Old 02-12-2008 | 09:33 AM
Registered User
It was the lifter thing that I was forgetting.
Thanks guys!
RickR
22
02-07-2010 01:04 PM
vasqufr
14
12-12-2008 12:45 PM
Smitty
09-17-2007 09:06 AM
Monty
4
08-20-2003 06:55 PM
