Gear shift cable switch help >
Old 02-12-2008 | 08:56 PM
Default Gear shift cable switch help
I'm getting a counter rotating lower unit for an older Formula with twin Alpha RH rotation. OK.. the lower units are available, but I have to change the gear shifting to "push", to have it shift in reverse and actually have the correct (LH) rotation. ANy ideas? Any kits around?
Does anyone makes a counter rot. lower unit that does not need shifting switch?? for Alpha 1?
THX . P
PARADOX is offline
Old 02-12-2008 | 10:40 PM
sunchaser796's Avatar
Answer is NO !! Ypu have to make the change in the controll box
sunchaser796 is offline
Old 02-13-2008 | 09:47 AM
Correct.
Just connect the shift cable up to the lever
on the opposite side ( from where the cable is currently connected)of the shift lever at the shifter quadrant.
JaayTeee is offline
Old 02-13-2008 | 07:35 PM
THe shift system is either by Formula or Quicksilver. (older type) Can't be done at the front shifter, I have to do it at the motor. I have to make some home made special reverse bracket or something.
PARADOX is offline
Old 02-13-2008 | 07:42 PM
Take a picture of your shifter. Nearly every one can be switched.
MOBILEMERCMAN is offline
Old 02-13-2008 | 08:23 PM
JasonSmith's Avatar
I don't think you can run an Alpha "backwards" like you can a Bravo.
I may be wrong or it may be the beer talking, but I just don't think it is as easy as it is on a bravo. At least on the older style Alphas.
JasonSmith is offline
Old 02-13-2008 | 08:40 PM
Jason..
Aftermarket counter rotating lower units are available. THey switch the "strong" forward gear to the reverse, but you have to run the drive in reverse.
I'm not 100% sold on this idea yet, but I will try it, (and keep the old lower unit in the garage. JIC )
PARADOX is offline
Old 02-13-2008 | 11:26 PM
[QUOTE=PARADOX;2444514]Jason..
[QUOTE]
Actually I think it is how the thrust bearings are put in the lower unit for a CR one. That being said, if you have the Quicksilver shifter, you should be able to switch it without a whole lot of hassle. I switched the one on my Stinger in less than an hour including adjustment. It's not that bad of a job at all. Does your shifter look like mine in the picture?
PS---you will love the difference in how the boat handles after you swap the CR on....
CCstinger260 is offline
Old 02-14-2008 | 09:09 AM
Yup. It looks just like that. I have to start taking it appart and take a closer look.
So what do I do.. take off the cable and turn it around re-installing to push????
Thx. P
PARADOX is offline
Old 02-14-2008 | 09:17 AM
Thx. P
The lever that the shift cable attaches to should
have an attachment point ( for the shift cable) on the opposite side of the levers pivot point.
JaayTeee is offline
