BPM vs #6 drives
Old 02-18-2008 | 01:54 PM
Default BPM vs #6 drives
First question is what are your opinions of both, positives and negatives of both (drivability, docking, resale, etc.). Second is can one be swapped out for the other, more specifically, can a boat with BPM's be swapped out for #6's? Is it a large process?
cullen_11 is offline
Old 02-18-2008 | 02:46 PM
Ballpark cost if anyone knows as well. Thanks.
Old 02-18-2008 | 04:38 PM
'05 Concept SF23
Totally differnt transoms. First is a BPM. Second is a NXT which is similar to a #6
Attached Thumbnails BPM vs #6 drives-dsc00396-medium-.jpg   BPM vs #6 drives-dsc00397-medium-.jpg
f311fr1 is offline
Old 02-18-2008 | 07:30 PM
but which will throw the nicer tail?
Perlmudder is offline
Old 02-19-2008 | 08:57 AM
44MTI's Avatar
They can be changed, BUT, you have to replace the transom because require different transom angles. This is very expensive, MTI just did it on a BPM boat.
As far as tails, typically the BPM with throw a lower, longer roost and the six will be taller but not as long, you pic which you like best.
Not a big deal but that is a #6 is the pic above.
44MTI is offline
Old 02-19-2008 | 11:41 AM
Mac's Avatar
Mac
You might ask Randy Scism his thoughts, I know he once told me that in his years of racing ect. that they had never had one break! Mine is very easy to dock, long ( no wake) idles you have to play with the shifters some. Bpm are quite a bit of a upcharge on a MTI
Mac is offline
Old 02-19-2008 | 02:16 PM
Rik's Avatar
Rik
arneson-industries.com
Offshoreonly Advertiser
As far as tails, typically the BPM with throw a lower, longer roost and the six will be shorter and higher, you pic which you like best.
This is why the Arneson is a smarter choice as the transom angle is the same standard boat transom as all the boats made have.
Rik is offline
Old 02-19-2008 | 03:06 PM
test
Joedecon is offline
Comanche3Six's Avatar
Thanks in advance for answering my next question.
Ed
Comanche3Six is offline
cowisl
03-24-2019 09:22 PM
taxguy
Drives and Lower Units
3
06-09-2007 08:57 PM
SLINGSHOT
02-21-2006 11:37 PM
timucin
07-26-2002 12:53 PM
Jeff-02
07-02-2002 02:29 AM
