Intake recommendation? >
Old 02-20-2008 | 09:36 AM
Default Intake recommendation?
Looking for a intake recommendation for 454 with AFR315's and Crane 741 Cam.
wphuddle is offline
Old 02-20-2008 | 12:17 PM
How much cam and comp do you have and what kind of rpm are you wanting to turn those are what I consider to be among the best heads on the market you should make great power.www.mesabalancing.com
SIncerely Laz
MESABALANCING is offline
Old 02-20-2008 | 02:16 PM
Laz,
I know enough about engines to be dangerous. Not sure yet on the cam and comp. these engines will be for pleasure boating mostly so I asume I probably want to turn 5500 to 6000rpm.
wphuddle is offline
Old 02-20-2008 | 02:23 PM
clone a hp 500, and put on a dart intake with a 750 or 850 dbl pumper . just watch the jeting on the carb
fastscarab22 is offline
Old 02-20-2008 | 05:25 PM
Vinny P's Avatar
I hate the winter!!
I built a 540 using AFR CNC'ed 315 heads. I tossed around intake ideas for a while but decided to go with what may be considered to be an unusual choice. I knew I wanted go with Dart but was a bit concerned about their rectangular port intake raising the power curves a bit too high. So, I went against the grain and used their oval port intake on my rectangular port heads. I gasket matched that last 2" of the runners to match my heads. It was alot of grinding but I think it paid off. My engine makes good power throughout its range.
Attached Thumbnails Intake recommendation?-pa150226.jpg   Intake recommendation?-pa200233.jpg
Vinny P is offline
Old 02-20-2008 | 05:39 PM
Vinny,
Excellent choice. I have been doing that for years now. The oval port intake has a smaller runner volume and works great when port matched correctly. It helps keep air speed up through the port resulting in more torque and broader power band. The Brodix HV Series oval port is also another great choice to perform this same operation on.
mrhorsepower1 is offline
Old 02-20-2008 | 06:34 PM
Vinny P's Avatar
I hate the winter!!
Originally Posted by mrhorsepower1
Vinny,
Thank you, coming from a pro like you, that makes me know I made the right choice. It made one hell of a mess grinding all that aluminum.
Vinny P is offline
Old 02-20-2008 | 09:09 PM
I was kicking around changing the intakes on my stock 454 mags, looking to save some weight anybody have advice on which intake would work best? would like to stay with stock carbs
Flamingo 42 is offline
CN24
3
03-10-2008 07:21 PM
Rambunctious
5
12-13-2007 09:35 PM
Prostreeter
25
03-08-2007 08:27 PM
Pat McPherson
14
10-04-2005 10:03 AM
paragon
26
06-10-2005 02:43 PM
