MEfi on RH inboard 330 MK4 454 ? Can it be done ? >
Old 02-21-2008 | 01:24 PM
Big Block Billy's Avatar
Lightbulb MEfi on RH inboard 330 MK4 454 ? Can it be done ?
Wanting to put a '98 Mercruiser 454 Iron oval port manifold Mefi Efi on a 330 Mk4 454 RH opposite rotation inboard.
Can this be done ? Dosen't the impulse comes off the ignition ? Maybe the efi can be Re-mapped ! This would be some great info to put in my back pocket !
I want to do this for one of my Dad's boats, motor is already in and was setup with a backward engine from the get go. Chrysler 440 from it BTW is rebuilt never used and in the shop if anyone needs it ...
Thanks, Bill
Big Block Billy is offline
Old 02-21-2008 | 03:57 PM
I can't see why not? The MEFI 1-4 has only two injector drivers so they're grouped 4+4. The cam shaft and distributor has std rotation even in opposite rotating engines.
The ECU probably has to be re-mapped anyway since I guess the oval port intake initiates from the Vortec engine with very different flow characteristics in the heads.
Alex is offline
Old 02-21-2008 | 04:05 PM
Unhappy
So I just use the .....79 Casting vortech heads and all appropriate sensors etc... and all systems go ?
Anybody else ?
Old 02-22-2008 | 08:41 PM
Dave_N's Avatar
Hey Billy,
Sounds like a fun project. So you are using a L29 MPI setup? A '98 would make it a MEFI 3? You would have to reflash the ECM, and it might take a little tweaking to get it right, but I think it could be done.
The two challenges that come to mind are injector timing and knock control. I don't know if the injector timing would matter much, since the injectors pulse on top of a closed intake valve. The L29's use two knock sensors which are "tuned" to a specific frequency and I don't know if they would work correctly on the Mk IV block.
I would contact Bob Radke at MEFIburn. He is THE man when it comes to MEFI controllers. He has been extremely helpful on a few issues that I have had.
Dave
Dave_N is offline
Ryan8886
7
03-20-2008 04:23 AM
fvracerone1
2
07-09-2007 06:49 PM
thanks_don
11-19-2006 08:24 PM
waterfun
10
02-26-2006 02:38 PM
