Water Injection
Registered User
Whatever happened to water injection? The concept has been around for decades. The technology is absolutely mature and the results are irrefutable. So then, why did it fall out of fashion?
It fell out of fashion because it is too cheap of a set up and guys laugh when you say water ... a few selonoids , a spray bar, a holding tank & fittings & hoses depending on how pretty u want to get . Its easier for these guys to sell u a blower, intercooler , & some pulleys for 5K and done deal for them . i'm sure you've done the research its working and if you want to take it a step further add a meth tank ... 400 ponies
I know of a few guys using methanol injection. Most people that I know opt for the meth. instead of the water. It does the same job of cooling the charge with the added benefit of upping the octane.None of it is real practical on a true pleasure boat. It can't be beat if you really want to make some big HP.
By the way, I remember helping my dad build one back in the mid 70's, on a 68 Ford truck with a 300 I-6. I was only 5 or 6. I only remember it because it was the first time he really let me help do something with meaning. It worked damn good, and it was an everyday driver. We even used it to tow the race boat all over the country.
Eddie
Eddie
There are a few of us considering Meth injection just for full throttle blasts. Several kits on the market and many ways to build a simple set up. Any of you have insight or have built one?
I'd like it just to prevent potential issues at WOT and our wonderful gas we now try to burn!!!
Man, water injection.... I built a few setups back in the late 70 early 80s.I un replumbed the polution pump those (air pump) those engines had on them right overtop of the carb. I put a "T" in the line and placed a smaller elbow on the "T". I had the elbow oulet flowing toward the carb. the inlet of the elbow was hooked to a water line comeing from a tank of water. The air pump would run when the engine was running the fast the engine ran the faster the air pump ran, the more preasure diferential there was on the outlet of the elbow causing it to suck water outof the tank. I put an orfice on the water pickup line to play with the amount of water untill it seemed "right". It worked pretty good. Ihad about $5 in hardware store fittings in the whole setup. Hey I was only 20 years old.
Feel free to E mail me or call me we have our meth set ups ready to sell along with complete teck support. We will be advertising on this site very soon. Our system incorporates nozzles into your carb adapter along with a a control box to start injection at any boost level you set it for as well as the proper high end pumps solenoids etc..Our system is designed to run 100% meth not 49 51. We recommend coming in with injection @ 7 to 8 lbs depending on your set up as well as a the ability to set up a progressive feed with the turn of a screw driver if needed with ulta high boost pump gas applications..
The only down side to all the power if there is one, is that the #6 drives are not designed to handle the high hp that can easily be attained with this system for a prolonged period and do take an added beating. We went through another pair of 6s last season and Craig Colabella is currently shaking his head installing all new gears top and bottom..he did ask what the hell are you guys running for power.It really works!
Glen 717-417-2900 or 717-324-7396
