True or False: MEFI 3 has TOTAL run time? >
Old 02-25-2008 | 03:14 PM
Default True or False: MEFI 3 has TOTAL run time?
I was told by one person they could only get the current time the engine was running, (as in right now) and by another that the total time is on the computer.
Anyone?
Fast Algae is offline
Old 02-25-2008 | 03:18 PM
It records the total run time.
mrhorsepower1 is offline
Old 02-25-2008 | 03:27 PM
CigDaze's Avatar
Lifetime total is recorded.
CigDaze is offline
Old 02-25-2008 | 05:08 PM
You can get both, just did this last week with Rinda ScanMate. First it shows total run time, and then when it goes into "scanner" mode, it will tell you how long it has been running, currently, since scanner was attached, along with a bunch of other "current" information.
bob_t is offline
Old 02-25-2008 | 08:55 PM
Thanks!
Old 02-26-2008 | 04:17 PM
Whipple Charged's Avatar
Yes, it also breaks it down into rpm intervals. You can also see the amount of time in knock retard. This can all be erased if you have the right software, so you can't always trust the hours.
Dustin
Whipple Charged is offline
Old 02-26-2008 | 07:44 PM
MEFI 3 does that? I thought it had to be the new, next generation (can't remember the name/number) that breaks down the rpm stuff?
Old 02-26-2008 | 10:04 PM
Yes, MEFI 3 does that as well. It doesn't break it down quite as much as MEFI4, but it certainly breaks down. Problem is, no current hand held scanners show the info. Maybe MEFI burn does, but not sure.
Dustin
Old 02-26-2008 | 10:11 PM
Dustin,
I once borrowed a scan tool from a friend that did show the entire break down of hours vs. rpm. I believe it was made by OTC. I not positive about the name, but I'm pretty sure. It had interchangeable cartridges that would allow it to work with all of the MEFI's and the 555, etc. It was a really nice piece. The only problem was it is a little big. It is probably 5 or 6 times the size of the Rinda.
Eddie.
Young Performance is offline
Old 02-27-2008 | 09:34 AM
Smitty's Avatar
My Rinda tool shows total hours, but not individual times at any rpms.
Smitty is offline
