MSD 8.5mm Plug Wires >
Old 02-26-2008 | 12:41 AM
axapowell's Avatar
Where To
Default MSD 8.5mm Plug Wires
Anybody have a part number for MSD 8.5mm wires that fit a HP500 Carbed motor? I will build them if I have to, but I am looking for a pre-made set. Running the stock Merc distributor and need 90* boots at both ends.
Thanks,
Dave
axapowell is offline
Old 02-26-2008 | 06:00 AM
I can order them for you I am a WD for MSD.
mrhorsepower1 is offline
Old 02-26-2008 | 06:18 AM
rchevelle71's Avatar
Would these be the same as a 454 330?? I will also need a set.
rchevelle71 is offline
Old 02-26-2008 | 07:13 AM
C_Spray's Avatar
Diamond Member #001
I just went through this, and wound up buying Taylor 8.2mm Thundervolt wires - $69.99 at Summit TAY-83253. They are available in blue and black, too. I did have to put the distributor ends on, but that was by choice - I wanted them to fit exactly right. Most of the wires were pretty close right out of the box, but everyone routes them just a little different. Fortunately, I had access to the special strippers/crimpers needed.
C_Spray is offline
Old 02-26-2008 | 10:39 AM
KEPP's Avatar
Only the Best Will Do!
Thanks,
Dave
The part number you are looking for is a #120-31489 8.5MM wire set. We have loads of them on the shelf and they are only $83.99. Our phone number is 386-446-0660 or feel free to shop securely at our website here the product link http://www.keitheickert.com/detail.aspx?ID=477
KEPP is offline
Old 02-26-2008 | 06:06 PM
Thanks,
Dave
Call me, I've got new wires i bought for the 500's that I never used, and thinking I never will with the 525's. You've got the number.
RaggedEdge is offline
Old 02-26-2008 | 08:23 PM
axapowell's Avatar
Where To
Thanks everyone...
Dave
Old 02-27-2008 | 12:11 PM
offthefront's Avatar
I just installed 2 sets of MSD 8.5's and they are nice wires cept I was dissappointed in the length's ... I might have ordered the wrong ones but as close I could see was BBC "under headers" They worked but I had to use my "plug wire stretcher" to get some to reach ...m
offthefront is offline
Old 02-27-2008 | 06:17 PM
Elite Marine's Avatar
http://www.cpperformance.com/detail.aspx?ID=477
Let me know if I can help guys.
Elite Marine is offline
mv35
Swap Shop
0
10-01-2008 12:17 PM
Need-the-Speed
5
08-11-2008 06:32 AM
mv35
Swap Shop
0
08-10-2008 08:36 PM
bajabob
4
04-03-2008 04:40 PM
ofshore
4
07-15-2003 05:36 AM
