Exhaust Gains
Old 02-28-2008 | 10:09 AM
Default Exhaust Gains
What kind of gains have you seen by adding an exhaust? What kind of boat did you put it on and which engine. I am looking at adding an exhaust to a 29 V with a 496 HO and am wondering what I'm realistically going to see, maybe 2 or 3mph?
Racerngr1 is offline
Old 02-28-2008 | 10:35 AM
Clay Washington's Avatar
Changing only the exhaust won't change anything except your bank account.
An exhaust change should be made in conjunction with other changes, like supercharging.
As a basic rule of thumb, you should only pay for performance upgrades if you can get 1 mph for each $1000 spent.
Good luck!
Clay Washington is offline
Old 02-28-2008 | 11:46 AM
The CMI's for the 496 HO's have shown pretty gains on the dyno over the stock system. They claim about 60hp, I think. Not sure if its true or not or the dyno numbers will transform into actual speed gains.
Griff is offline
Old 02-28-2008 | 11:50 AM
Dave M's Avatar
Veteran: Navy
A guy with a 22 Donzi was saying he didn't gain much if anything with the 496/CMIs. I'd think 60 HP in that boat would yield at least 3 MPH.
Dave M is offline
Old 02-28-2008 | 12:39 PM
Stormrider's Avatar
JC Performance Engines
i'd only upgrade an exhaust if the current one was shot.
Stormrider is offline
Old 02-28-2008 | 01:05 PM
trc2's Avatar
scarab
I had a 454 mag 385 H/P changed from stock exhaust to imco power flo exhaust and gained 2 + mph on a 1997 22 foot scarab
trc2 is offline
Old 02-28-2008 | 01:45 PM
R Addiction's Avatar
AT Cult Member #3
Your gain was probably 1/2 and 1/2. With 1/2 of it coming from weight loss, and the other 1/2 from allowing it to breath a little better. I did say probably....
R Addiction is offline
Old 02-28-2008 | 01:46 PM
AT Cult Member #3
Or your dreammeter is not accurate
Old 02-28-2008 | 01:53 PM
I have personally seen several boats pick up anywhere from 3-5mph with CMIs on HOs. I think a twin 496 cat picked up 9mph. One that comes to mind was a 26 Eliminator V that picked up 5mph and a prop size. Chances are you're going to pick up several mph and a really nice exhaust sound.
ToMorrow44 is offline
Old 02-28-2008 | 06:30 PM
trc2's Avatar
scarab
That was with a GPS
trc2 is offline
