Throttle/Shifter Control??? >
Old 03-10-2008 | 05:08 AM
cig1988's Avatar
Default Throttle/Shifter Control???
What is the diode #9 used for and does it tie into the trim or neutral safety circuit?
http://www.mercruiserparts.com/Show_...PAGE+1+OF+2%29
cig1988 is offline
Old 03-10-2008 | 09:26 AM
hoozeyurdaddy's Avatar
it ties into the trim sys. it is used for triming twin engines with a single switch on the throttle control.
hoozeyurdaddy is offline
Old 03-11-2008 | 02:36 AM
cig1988's Avatar
This may sound dumb but is it really necessary?
cig1988 is offline
Old 03-11-2008 | 06:25 AM
Registered User
Only if you want it to work.
Chris Sunkin is offline
Old 03-12-2008 | 03:33 AM
cig1988's Avatar
LOL somehow I knew that was the answer
cig1988 is offline
Old 03-13-2008 | 03:05 AM
cig1988's Avatar
Seriously, someone 'splain this to me like I'm a 2 year old. I know that a diode allows electric flow in one direction. If the circuit from 2 electric motors are in series controlled by a switch, why is that needed?
cig1988 is offline
Old 03-13-2008 | 04:42 AM
Registered User
If you want to control two motors with one switch but still have individual control of each motor with it's own switch, you need the diode. If you don't have the diode, you're basically going to activate both motors with all three switches. The diode blocks the current from going to the opposite motor when using the single switch.
Old 03-13-2008 | 05:19 AM
cig1988's Avatar
Okay, I see the sole purpose of it now. I'm helping out a friend with a 42' Excalabur. He is looking to use only the switch on the controls. Personally I think that is not the way to go. If you are using 1 switch for 2 engines you would not need the diode?
cig1988 is offline
Old 03-13-2008 | 11:55 AM
He can use just the one switch in the throttle for both drives. In order to retain the individual dash switches for each engine, it needs the diode.
Griff is offline
axapowell
Wanted
7
04-01-2008 08:02 PM
propmanage
Beware and Stolen
4
07-20-2007 08:38 AM
S4Hadi
3
03-20-2006 07:48 PM
SkiDoc
9
10-07-2005 08:13 PM
Wildfire
3
05-03-2002 10:51 PM
