B-Max drives???
Old 03-13-2008 | 08:54 AM
Default B-Max drives???
Good? Bad? Thoughts?
Can they take 750 hp?
SinkorSwim is offline
Old 03-13-2008 | 09:00 AM
BBB725's Avatar
They will handle 750 hp without a problem but you will lose a couple mph with them.
BBB725 is offline
Old 03-13-2008 | 09:36 AM
KAAMA's Avatar
Also, you can do a search on B-Max and you should find a few threads/discussions with pros and cons about their drive.
KAAMA is offline
Old 03-14-2008 | 06:28 AM
Canada Jeff's Avatar
The only 'con' is the lower gear set isn't any larger than a standard bravo XR drive. So if your blowing lowers, keep this in mind.
Just my 2 cents.
Canada Jeff is offline
Old 03-14-2008 | 11:55 AM
Just my 2 cents.
You have some experience in this department, blower boy?:
pasquesi is offline
Old 03-14-2008 | 12:30 PM
Strip Poker 388's Avatar
Rob
They have a 1 year warranty up to 950 HP and TQ.You can also buy a extended warranty that is reasonable
Attached Thumbnails B-Max drives???-drives%25204-7-07%2520003%2520%2528large%2529.jpg   B-Max drives???-drives%2520redo%25204-10-07%2520012%2520%2528large%2529.jpg   B-Max drives???-11-07%2520%25231%2520193.jpg
Strip Poker 388 is offline
Old 03-14-2008 | 03:22 PM
Strip, Quit hoggin all those for yourself.
Back4More is offline
Old 03-15-2008 | 07:45 PM
Rob
stock is getting low
Old 03-17-2008 | 07:13 AM
I break uppers....so far....
Old 03-17-2008 | 07:33 AM
racer-x6's Avatar
Why do you need so many if they are so good
racer-x6 is offline
Fenderjack
02-06-2007 04:38 PM
NOMOGOFAST
0
04-04-2006 07:44 PM
docmanrich37
02-09-2006 07:46 AM
docmanrich37
5
01-24-2006 07:12 AM
trader1
04-07-2004 09:50 PM
