msd 6m2l installation? >
Old 03-15-2008 | 08:09 AM
tgersx's Avatar
Default msd 6m2l installation?
i'm installing new msd 6m2l boxes to replace my factory merc igntion system, however i still want to use my factory distributor. In the diagram they show to still use the igntion amplifier? is this my thunderbolt module?
tgersx is offline
Old 03-15-2008 | 08:15 AM
yes you have to keep that hook up
bajabob is offline
Old 03-15-2008 | 12:35 PM
I posted on the thread in GD.
Griff is offline
Old 03-16-2008 | 01:18 PM
articfriends's Avatar
Before installing the boxes get them tested,after years of me defending msd and never having any problems with there ignitions I replaced my std automotive msd box with the same ones you now have and was PLAGUED by a season of ignition problems. After the second box worked intermittently I bought a msd box tester for 150$,when box #3 showed up I immediately put it on the tester,it was dead on arrival!!. The problem I found was the wires are crimped going into the box which caused it to work intermittently or not at all,when I called MSD for the 15teenth time they had never heard of anyone else with my problem,I am done with them and I had too many trips to the water that required me to work on the ignition (at the dock returning it to stock for the day). It was never a poor installation as the msd box tester proved,you would wiggle the wires going into the box and it would work for a little while or you would hit a wave and the ignition would cut out/quit,Smitty
articfriends is offline
pkspx
61
08-20-2015 09:06 AM
tgersx
03-15-2008 12:34 PM
cloudmaster_321
6
06-04-2007 07:47 PM
Thunder32
6
03-18-2004 01:33 PM
