Best Way to Strip Outdrives? >
Old 03-24-2008 | 08:37 PM
pshannon's Avatar
Default Best Way to Strip Outdrives?
Hey guys my outdrives need a good repainting so I want to strip them down and repaint them in mercury black...So what do you guys think is the best way to take the old paint off?
I might do black/silver I don't know..
pshannon is offline
Old 03-24-2008 | 08:43 PM
comininhot's Avatar
Lett me pull them off and you can blast or sand them in youre garage and then hang them or put on engine stand I will lend you one, call me.
comininhot is offline
Old 03-24-2008 | 09:26 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
I'd lightly sand the original paint and shoot over it if possible. That original paint is hard to get off and is 200x more durable than any paint you put on it. It'll make for an excellant base.
US1 Fountain is offline
Old 03-24-2008 | 09:46 PM
jeff32's Avatar
My first thought was 1500HP...
Until I read the tread!
jeff32 is offline
Old 03-24-2008 | 09:50 PM
DollaBill's Avatar
OSO OG
Absolute, Tequila, my portable stripper stage and any other things you might enjoy.
Oooooh, you said outdrives.............
DollaBill is offline
Old 03-24-2008 | 10:24 PM
pshannon's Avatar
Well if we are going to do that then we should do new seals and an impeller while they are off to right?
pshannon is offline
Old 03-25-2008 | 02:18 AM
Registered User
The drives are powder coated. The best way to get powder coating off is the same way it went on- heat. Take them to a powdercoater and let them put the drives in their oven- 400 degrees or so should do it. The stuff will just fall off. Plus, you'll leave the conversion coating that's applied to the drive for anti corrosion intact. Sanding or sandblast will remove it
Chris Sunkin is offline
Old 03-25-2008 | 08:08 AM
Roger 1's Avatar
Are you sure that Mercury powdercoats their drives? I was at Mercury Racing for a tour last spring and they said that they did'nt powdercoat but painted them.
Roger 1 is offline
Old 03-25-2008 | 08:26 AM
cigrocket's Avatar
Konrad powder coats, mercury does not.
cigrocket is offline
Old 03-25-2008 | 09:36 AM
contact Doller Offshore, they can paint and redecal the trs like it was brand new ( as long as the housings aren't pitted etc)
ARTnPARTS is offline
