Oil Releif Valves Gen 6 Block >
Old 03-28-2008 | 07:01 PM
racinfever's Avatar
Default Oil Releif Valves Gen 6 Block
Just tor down 500 efi motor for freshen up & noticed no oil releif valve in the main oil port, This is a merc factory motor. Is it missing or not needed ? IN the past all gen 5 & 6 blocks have had it.
racinfever is offline
Old 03-28-2008 | 08:13 PM
H2Xmark's Avatar
are you talking about at the oil filter lines that hook up to the block?
H2Xmark is offline
Old 03-29-2008 | 02:16 AM
It's not required, or recommended in the outlet port of the filter pad. make sure you replace the other one next to the nipple with the 30lb bypass valve. part#25161284
HaxbySpeed is offline
35 White Lightning
1
05-31-2007 09:20 PM
35 White Lightning
0
05-31-2007 08:11 AM
GNJ
3
05-23-2007 12:15 PM
ratman
30
08-25-2005 07:37 PM
cooltoys61
16
06-21-2005 08:46 PM
