mercruser 500 carb/efi >
Old 03-31-2008 | 07:19 PM
Default mercruser 500 carb/efi
Can I convert a mercruiser 500 carb motor to a efi motor if so where is the best place to find the efi system
jab052783 is offline
Old 03-31-2008 | 09:18 PM
H2Xmark's Avatar
you might give dustin whipple a call, some of his supercharger kits replace the intake and he can map you an ecm ,
H2Xmark is offline
Old 03-31-2008 | 09:26 PM
I Have Everything You Need.
chad1 is offline
Old 04-01-2008 | 06:37 AM
Canada Jeff's Avatar
Why would you want to?
Canada Jeff is offline
Old 04-01-2008 | 06:42 AM
scottc's Avatar
Go to www.cbpba.com and there is one there complete for $2000.
scottc is offline
Old 04-01-2008 | 11:08 AM
I agree. The 500 carb is a very good engine. It is going to cost quite a bit to get everything to do it right. If you don't get it exact, then you will have to re-program the ecm. I would just put an aftermarket efi system on like one from Holley(Commander 950) or Edelbrock(Pro Flo). I like the Holley system and use it very often. I buy it without their electronics and use a Mefi computer and harness. It has the ability to make a ton of hp without any modifications, unlike the 500 efi setup, which takes a lot of work to get much past 600-650 hp.(extrude hone or port, bigger throttle body, etc). I have complete kits available. Let me know if I can help you. Thanks, Eddie.
Attached Thumbnails mercruser 500 carb/efi-650-efi-001-large-.jpg   mercruser 500 carb/efi-650-efi-002-large-.jpg   mercruser 500 carb/efi-650-efi-003-large-.jpg
Young Performance is offline
Old 04-01-2008 | 04:01 PM
Stay with the Carb.
formula 382 sr-1 is offline
Old 04-02-2008 | 06:13 AM
It makes no sence going from a carbed hp500 to an efi 500. More money for no more performace. Doesn't make sence.
So I ask again......Why?
Old 04-04-2008 | 03:08 PM
Hey Eddie,
If you use the aftermarket EFI systems do they allow you different outputs to control other things, ie nitrous? How adjustable are they if you do a cam swap or header swap? Do they use an o2 sensor or is it closed loop?
quadracr is offline
Old 04-06-2008 | 12:13 AM
I'm using a mefi computer. Personally, I think they are the best. They also allow my customers to have their engine worked on by any qualified Merc mechanic should they have a problem. Since I'm shipping engines all over the place, it is not convienient for every customer to come back to me with every little problem. They have the option to go somewhere close to them, wherever that may be. Not many builders use mefi computers because they either don't have the software or don't know how to use it, since it is fairly complicated software.
I do use a wideband O2 sensor to tune (actually a dual sensor, one in each bank), but it comes out after the tuning is done. This computer is highly tunable. You can make as many changes as you would like to accomodate any engine mods. Hope this answered your questions, Eddie.
