? about putting in a depth gauge >
Old 04-01-2008 | 08:15 AM
STUCK's Avatar
Default ? about putting in a depth gauge
I have a 2005 275 and am going to put in a depth gauge. The question I have is, is there an easy way to place it above the trim tabs indicators? I haven't look yet but my dad has since it is in there garage during the winter but he said there wasn't a way to get to that location when he took the dash out. He said maybe if we take the speaker out in the cabin we might be able to reach it. Again I haven't looked myself yet. It's to the right of the gauges above the trim indicators. I've seen them located there so I know they can.
Thanks.
STUCK is offline
Old 04-01-2008 | 01:38 PM
I didn't get this option either when I bought mine. I had my current dealer put it in where the factory would have for around $200. From what I can remember - it cost ~$375 total out the door.
five cent worth is offline
Old 04-03-2008 | 12:38 AM
Thanks.
Use a through hull then you don't have to mount it outside the boat and drill holes...
Irishtornado is offline
Old 04-03-2008 | 06:47 AM
STUCK's Avatar
I have the one that will sit in the bilge. It's trying to put it in the dash. My dad took the dash off and I thought he said he couldn't get over to the side where I want to put it and I know it can go there because that's where I see most of them. But I haven't checked to see for myself.
STUCK is offline
Old 04-03-2008 | 07:18 PM
Tinkerer's Avatar
Stuck - is your boat a step hull? If it is the sender will need to be installed in FRONT of the first step. If you don't it won't work with the boat planed out.
Tinkerer is offline
Old 04-03-2008 | 07:37 PM
Registered User
No steps on the old baja's...Who knows about the new Fabaja's that are coming.
320es is offline
Old 04-08-2008 | 01:08 PM
Take the speaker out and reach up. You will feel the area where you want it to be.
Get the correct size hole saw, tape it off and drill your hole.
I added the Clarion remote next to the steering wheel - it was pretty easy to do. You definitely want the depth finder up above the trim tabs, it is the best place to see it.
I may have some pictures I took through the speaker hole. When I get around my home pc I will take a look.
jswfl09 is offline
Old 04-13-2008 | 08:39 PM
STUCK's Avatar
Thanks Jim09091 I'll give that a try and see if it works.
STUCK is offline
bv280
Powerquest
7
09-05-2008 06:14 AM
FormulaM2Formula
02-18-2007 08:33 PM
US1 Fountain
Fountain
17
07-23-2005 11:25 PM
blownboat
3
05-31-2004 10:50 AM
technicalx
Baja
4
09-24-2003 07:33 PM
