502 valve cover baffles >
Old 04-01-2008 | 05:22 PM
Default 502 valve cover baffles
Hello, I have a stock set of valve covers and need to remove the baffles. With this baffles removed will I suck more oil thru my PCV valve what are any other options. Thanks Jeff
alecsammy is offline
Old 04-01-2008 | 09:38 PM
Smitty's Avatar
Why do you need to remove the baffles???
Smitty is offline
Old 04-02-2008 | 07:14 AM
You need the baffles if you're running PCV valves.
kennyo is offline
Old 04-02-2008 | 04:53 PM
I'm changing the stock rockers to summit's roller rockers.
Old 04-02-2008 | 07:49 PM
Cheap way......Use two rubber gaskets under each cover.
speedreeder is offline
Old 04-03-2008 | 01:48 AM
You need to grind off the corners on the #1 and #7 intake rocker arms. That is even what Merc did to the Crane rockers on blue motors.
Griff is offline
Old 04-03-2008 | 02:16 AM
MM1
Don't buy the summit brand anything for your valve train unless you like holes in your pistons.
MM1 is offline
Old 04-03-2008 | 12:28 PM
Why???? I ran them just fine on a hopped up 454mag. I certainly wouldn't put them on more that a 600hp engine though.
Griff is offline
Old 04-03-2008 | 01:31 PM
fountainfevr's Avatar
Have crane roller rockers and doubled up Fel pro neoprene gaskets it leaked big time it was that way when I bought the boat. I bought the taller valve covers from eddie marine red fusion coat problem solved!!!
fountainfevr is offline
Old 04-03-2008 | 01:56 PM
Jeff, Eric at EB marine has a set for $50 plus S&H. That's a deal. Probably need paint. His # is 6157142944
kennyo is offline
