Suburban HELP
Old 04-05-2008 | 04:36 PM
nordic95's Avatar
Default Suburban HELP
Hey guys I have an 04 surburban with a bad power window motor on the drivers side.I removed the motor and the darn cables poped out on me and I've been trying to get all the slack out and wind it back up on the spool for three hours now.Does anyone have any secretes on how to do this?I'm ready to take it to the dealer or smash it.HELP. I already removed the glass but everytime I wind it up and go to set the regulator in place I end up with a bunch of slack.
Thanks Noridic95
nordic95 is offline
Old 04-05-2008 | 05:01 PM
get a new regulator
eliminatethis is offline
Old 04-06-2008 | 09:31 PM
rchevelle71's Avatar
on my '01, you have to replace the whole regulator/cable/motor assy.
rchevelle71 is offline
Old 04-07-2008 | 06:57 AM
Airpacker's Avatar
You are one turn short on the wrap if you have slack. They are a real bugger to put back together. Good Luck.,
Airpacker is offline
Old 04-08-2008 | 11:00 AM
GM (and almost all car mfg's.) have gone to the cable/nylon track/motor window regulators for at least the past decade. They are cheaper to produce and lighter in weight than the old steel track/regulator assemblies (that rarely failed).
If you fail a motor only, you're in luck. You can replace just the motor if the cables and regulator are still serviceable. Otherwise, you have to replace the entire assembly. You have little chance of rewinding that sucker and making it work with any kind of longetivity. The usual scenario of failure on them is for the window to fall to the bottom of the door with the cables in a big snarl.
I've had to do all 4 on the Bonneville over the course of the last 3 years.
The big box they come in says 'always use genuine GM parts' on it. In the corner it says "Made in South Korea"
jafo is offline
Racerngr1
38
12-11-2007 08:22 PM
Liquid Fix
16
06-08-2006 07:16 AM
Advantage_Rob
12-07-2002 12:15 AM
