What would take these Scratches out???? >
Old 04-10-2008 | 12:35 PM
pshannon's Avatar
Default What would take these Scratches out????
Ok so this is the 3rd year I have had my boat and over that last 2 years the boat has recieved these scatches. They are from my boat lift, it has the pvc pipes on both side to guide it in but they are to short. So everytime I pull into my lift the poles would rub underneath the rubrail on the sides of the boat. They are like strip of plastic not scratches so to speak.. Please help..
The boat:
The scratches:
pshannon is offline
Old 04-10-2008 | 12:41 PM
Sydwayz's Avatar
Forum Regulator
Those look like scuff marks of PVC actually scrubbed onto the paint. I would thing those would come out, but will take a lot of work.
Did you put longer PVC poles on your lift yet?
Sydwayz is offline
Old 04-10-2008 | 12:49 PM
BY U BOY's Avatar
Use Donnies oxidation remover and a clean rag then follow up with leverage. I hadsome similar on mine and they came right out. Good luck!
BY U BOY is offline
Old 04-10-2008 | 01:28 PM
Knot 4 Me's Avatar
Gel or paint? If it is gel and PVC marks acetone will take it right off.
Knot 4 Me is offline
Old 04-10-2008 | 01:36 PM
Registered User
That's why I don't fukc with lifts..
That sh!t would piss me off.
Southocg is offline
Old 04-10-2008 | 01:37 PM
pshannon's Avatar
That exactly what they are and yes the new pole will be on when I put it in the water..
pshannon is offline
Old 04-10-2008 | 01:40 PM
They look more like scuffs...try # 50 Cleaner Wax it removes scuffs real good.
Back4More is offline
Old 04-10-2008 | 02:04 PM
pshannon's Avatar
It's actually like a film, I can peel if off a little with just my finger nalil...
pshannon is offline
Old 04-10-2008 | 02:30 PM
Two suggestion, for prevention.
1. Extend the pole guides out a little more at the bottom.
2. Put some special cloth sleeves over the pipe's.
Someone can sew them up for you before you really do some real damage..
Good luck.
AB From Windsor is offline
Old 04-10-2008 | 02:32 PM
I second the acetone, get a quart for about $4 at the local parts store. Just put a little on a rag and wipe those right off. Thats the only thing I've ever used to remove scuff marks. Just wipe a little wax over it once removed.
Brandon is offline
