Silicone removal
Old 04-10-2008 | 05:20 PM
Default Silicone removal
What can I use to remove silicone from my transom with out damaging the gel,I am replacing my exhaust tips and the new tips are a little smaller.
thanks
boatnt is offline
Old 04-10-2008 | 05:25 PM
Beefy wood chisels work well. If it was any kind of good quality silicone you may have a hard time removing 100% of it without slightly scratching or marring the gelcoat inderneath it. You can sand/buff out minor marks in gel.
THRILLSEEKER is offline
Old 04-10-2008 | 05:40 PM
Try a new rasor blade and soapy water. Acetone will remove most silicones. If it's to hard.!? mild MEK with water or even Xylol deluted with water.
I had good luck removing all types of silicone and rubber with those three methods.
Carefull with MEK and Xylol. Tough chit.
PARADOX is offline
Old 04-10-2008 | 07:22 PM
Just tell the girls to get off your transom!!!!!!!!!!!!!!!!!
THLWL is offline
Old 04-10-2008 | 08:23 PM
Acetone or Laquer Thinner. Just put some on a rag and rub the silicone off with your finer.
ToMorrow44 is offline
Old 04-10-2008 | 08:29 PM
AKA "BAZOOKA JOE"
home depot has this new product its green in color in the silicone isle comes in small tubes but works good losens it up so it peals off
bojoe2 is offline
Old 04-10-2008 | 09:12 PM
Shanghied Again's Avatar
Registered User
I use Acetone to get off excess silicone.
Shanghied Again is offline
Old 04-10-2008 | 10:00 PM
sunchaser796's Avatar
There isn't much that will hurt gelcoat surface except wood chisels and razors blades. I have learn the hard way and spent hours try to repair the damage. You may also try 3 m product that is made from citrus . It works well..
sunchaser796 is offline
teaguecustommarine
New Products and Member Discounts
1
03-02-2007 02:51 PM
rangerrick63
Detailing, Painting, & Fiberglass
4
01-05-2007 02:15 PM
Shah Mat
0
06-22-2006 12:20 PM
blownboat
12
01-09-2004 05:20 PM
