Hydralic Steering Resivor
Old 04-15-2008 | 06:14 PM
Default Hydralic Steering Resivor
do you need a resivor tied into your pump on a full hydr. system and if not what are the benifites of having one? my imco system did not come with a tank. thank's.
scarabfun is offline
Old 04-15-2008 | 06:34 PM
you dont need a resavoir. my imco doesnt have one either.
5050 is offline
Old 04-15-2008 | 06:40 PM
what's the beni of one?
Old 04-15-2008 | 08:29 PM
It adds fluid volume and allows the steering wheel to be turned more easily, especially at idle.
Griff is online now
Old 04-15-2008 | 10:00 PM
Elite Marine's Avatar
Plus it helps bleed air out of the system, while maintaining fluid level.
Have some really nice ones here:
http://shop.elitemarineonline.com/pr...&productId=211
Elite Marine is offline
Old 04-16-2008 | 07:33 PM
CPPerformance's Avatar
I would say that if you have a full hydraulic steering system with 2 rams it would be a must.
Here is a press release for the new reservoir that we just released:
Performance boaters who step up to an aftermarket hydraulic steering system can encounter problems. A common one occurs when the factory power steering pump won't hold enough fluid to support all the additional hoses and plumbing of the steering system.
CP Performance of Rohnert Park, CA, has solved this problem by developing and fabricating an aluminum reservoir that has twice the capacity of the original plastic version. It's designed to fit an OEM or an aftermarket-style pump. The large-capacity power steering reservoir is more durable and functional, with 39 ounces (or 1.2 quarts) in size. It's currently being sold on its own for boaters using full hydraulic steering systems, but will soon be available in a kit that includes all the necessary components to add a complete power steering pump assembly to your engine -- power steering pump, pulley reservoir and billet port cylinder head mount kit.
The reservoir is on display at the CP Performance booth at the Los Angeles Boat Show, and will be featured at the display at the Miami International Boat Show as well.
Hope that helps! Good Luck
Brad
For more information, call CP Performance at (707) 585-9871.
CPPerformance is offline
Sick Stinger
Wanted
4
05-09-2008 03:02 PM
nocigarette
Do It Yourself, Boating on a Budget
6
04-14-2008 07:15 AM
p4-33
11
05-02-2004 11:30 PM
alj
0
07-01-2003 09:45 PM
