HELP....   need advise from you gurus .. >
Old 04-16-2008 | 04:29 AM
Default HELP.... need advise from you gurus ..
: Quesyion ...! ! What would be the real speed ...
For a Cigarette 35 Cafe Racer weighing 5511 Lbs , less engines and drives ,
Now with a pair of 502ci / 415bhp year 2000.. with Bravo 1 drives , i guess they weigh 2600 Lbs both of them ,
Total weigh of both & fuel being 8500 Lbs
what propellers would you take in consideration to have a good speed .... with this set up . !
is it possible to reach 70mph ???..: Whatever:
Clyde
clyde cutajar is offline
Old 04-16-2008 | 05:27 AM
probably 64-66 tops my guess
dreamer is offline
Old 04-16-2008 | 05:32 AM
http://www.offshoreonlyclassifieds.c...o19348-en.html
similar idea
dreamer is offline
Old 04-16-2008 | 05:43 AM
Audiofn's Avatar
Charter Member #232
How are you coming up with your weight? I think a Cafe fully rigged is going to weigh a lot more then that.
Put your best foot forward!
Audiofn is offline
Old 04-16-2008 | 05:55 AM
Default RE: i weighed the boat when i bought it
i have come up with the idea for the weight ,,,,,,,,,,because i have a 35 cafe racer 1987 model , and i weighed it less angines drives and empty from fuel ...........but with all other amenties inside ..and the weight was 5511Lbs.
So i said with the 502s weighing another2640Lbs plus 500Lbs of fuel The total weight of the boat would be
Approx. 8500Lbs..
Regarding the 66mph , target , ! !
would it be possible with extension boxes , stainlesssteel tail pipes exhaust and good props possible
to reach the 70mph barrier !!!!
Clyde
Old 04-16-2008 | 07:51 AM
seafordguy's Avatar
Approx. 8500Lbs..
Clyde
Unfortunately You aren't going to see 70 with 415's in a full pleasure Cafe to save your life. I too am surprised about that weight considering the attached.
Attached Thumbnails HELP....   need advise from you gurus ..-cigarettecaferacerad.jpg
seafordguy is offline
THRILLSEEKER
10-04-2004 02:10 PM
jryan26
52
09-20-2004 08:10 PM
THRILLSEEKER
08-17-2004 07:51 AM
