Bravo drive coupler/Big power >
Old 04-16-2008 | 05:08 AM
tomas_wallin's Avatar
Default Bravo drive coupler/Big power
What drive coupler do you guys with big power and Bravo style drives use?
Is there any other than the Merc Hi-Perf one? What about a spring loaded one like the ones that are used with trannys?
There must be some plates that fit Bravo's that's not the rubber ones, right???
tomas_wallin is offline
Old 04-16-2008 | 09:14 AM
hoozeyurdaddy's Avatar
there are some aftermarket couplers out there for hi perf. stay with the rubber couplers, they save all the shafts in the drive, there are a lot of boats out there running 1000 hp+ with the rubber couplers and hold up fine.
hoozeyurdaddy is offline
Old 04-16-2008 | 11:59 AM
I used a Merc HD long snout steel coupler when I replaced the coupler on my Pantera.
Its is merc part #861523A7
Griff is offline
Old 04-16-2008 | 07:40 PM
Smitty's Avatar
I run what Griff mentioned and I have about the same HP as you do.
Smitty is offline
Old 04-17-2008 | 12:09 AM
articfriends's Avatar
I'm running the merc long snout hp,its been in my boat for 5 years,2 w/750 hp,2 w/950 hp and the past year with 1057,still looked 90% good last time it was out,I wouldn't buy anything else unless your having problems,Smitty
articfriends is offline
Old 04-17-2008 | 12:36 AM
Outdrive1's Avatar
Masher touches my
Not that couplers never break, but everything in the Bravo drive is probably weaker than the coupler. I've seen Alpha boats with bad couplers, I think they fail at random or from manufacturer defects more often than from hp.
Outdrive1 is offline
Old 04-17-2008 | 12:55 AM
Alignment is very crucial, and soft or flexing transoms will eat up any coupler.
Bawana
Bawana is offline
Old 04-17-2008 | 01:01 AM
Outdrive1's Avatar
Masher touches my
Bawana
Good point, I didn't think of that.
Old 04-17-2008 | 03:30 AM
Alignment and lack of grease are the main reasons a coupler fails. The steel snout also is stronger than the aluminum ones.
Griff is offline
Strip Poker 388
Wanted
6
06-25-2008 07:09 AM
Ford Capri
8
03-18-2007 04:13 PM
klaw
20
07-24-2005 03:40 PM
JIMKID Motorsports
05-18-2003 07:14 AM
Tee
01-06-2003 04:31 PM
