Fuel Pump Return Line >
Old 04-16-2008 | 09:44 PM
Default Fuel Pump Return Line
I'm running a carb with a electric fuel pump. I ran a return line from the regulator back to the tank. I have two pickups in the tank. They are threaded into the tank. Should I remove the actual pick up and just dump the fuel in the top of the tank or is it ok to use the pick. That would put the return fuel into the bottm of the tank.
Mike
Noise Pollution is offline
Old 04-17-2008 | 12:39 AM
Outdrive1's Avatar
Masher touches my
Mike
I don't think that you need to return it to the bottom of the tank, although it would probably create less fumes etc. Most tanks just have the return line plumbed to dump from the top. I really don't think it's going to make a difference personally.
Outdrive1 is offline
Old 04-17-2008 | 05:14 AM
nocigarette's Avatar
mine are both plumbed into the tubes,in my deal it helps keep the fuel more equal in the tanks...
nocigarette is offline
Old 04-17-2008 | 11:05 AM
BY U BOY's Avatar
I would be worried about stirring crap off the bottom of the tank.
BY U BOY is offline
Old 04-17-2008 | 11:55 AM
Dont ya think ruff water would due that anyway....
Old 04-17-2008 | 12:03 PM
BY U BOY's Avatar
youre right.I'm still sleepy
BY U BOY is offline
Old 04-17-2008 | 12:25 PM
I just did mine and was told to return to the top of the tank because of the pressure.
Michael Garibay is offline
Old 04-17-2008 | 12:56 PM
I started thinking about after I got it hooked up. I think I'll change it.
Old 04-17-2008 | 05:59 PM
Strip Poker 388's Avatar
Rob
CP perf makes a inline pipe you put in the filler tube.
Strip Poker 388 is offline
Old 04-17-2008 | 07:39 PM
Nice idea, but its easier to get to the second pick up on the tank than the fill line. Today i took the pick up out and put a
90* in its place and hooked the return line to it.
