2008 gmc biult in brake controller >
Old 04-19-2008 | 02:54 PM
crayolacrazy's Avatar
Default 2008 gmc biult in brake controller
I have 2008 GMC with biult in brake controller and it dont work on my boat trailer ,my old truck does ,my 08 works on my cargo trailer so im thinking its the controller any one see this issue please call Bob 412 7810881
crayolacrazy is offline
Old 04-19-2008 | 03:07 PM
the 08 GM controller doesnt work with EOH brakes,,,they may make an adapter like the Fords but Im not sure
Bottomfeeder is offline
Old 04-19-2008 | 03:33 PM
who sells the adapter
Old 04-19-2008 | 04:08 PM
go to ''diesel place . com'' and search eoh or factory controllers, you can a electric magnet from a electric drum brake setup and fix the problem,,its caused by the controller not getting pinged by the eoh setup
dmaxx3500 is offline
Old 04-19-2008 | 06:58 PM
can you call me Bob 4127810881
Old 08-11-2008 | 08:59 PM
Crayola Crazy,
Were you able to correct your problem based on following Dmaxx's advice? I have an Avalanche w/ a Prodigy controller it works fine on my DMC / Skater Trailer. Test drove 2- 2008 Chevrolet Silverado's this past weekend & neither brake controller operated my brakes so I was curious as to what you did to solve your problem. Lights & signals worked fine but that about it.
Michael
NASCAT is offline
Old 08-11-2008 | 09:03 PM
30 outlaw 2005's Avatar
Make sure that you check the connections for the electric brakes under the hood. The vehicle is delivered to the dealer with out the connections made, Selling dealer has to connect the wires for it to work. Could be one of the problems your having.
30 outlaw 2005 is offline
Old 08-12-2008 | 12:45 PM
Just wire a magnet from electric brakes in series to the activation wire. The 08 Ford's will not run EOH either and there is no adapter for the 08 Ford. I called the engineer for Carlisle and he told me off the record my idea would work, and it does. No problems at all.
Screamin' Seamen' is offline
Yamaha 225
18
09-08-2008 11:48 AM
bjablonski
7
04-26-2008 09:57 AM
rjr
2
04-02-2008 10:23 AM
duksrule
4
07-03-2006 12:40 AM
J.B. Marshall
0
05-15-2006 05:03 PM
