rocker / lifter noise???
Hi All
I trying to solve this upper engine noise so far I replaced the lifters adjusted them several times changed the cam , and upgraded to roller rockers and the noise is still there. I also change at the beginning of this project is the pushrods which are one piece style . I ran the engine and the oil pressure is 40 lbs at idle , with the valve cover off the oil is pumping out of the pushrod but not a real lot. Has anyone came across a problem with pushrod not mating up correctly with the lifter.The diameter is smaller with the one piece pushrod compared to the stock rod. The engine is a 98 502 and I changed evrything on the top end. The rockers clear the covers and the noise is still there with them off. Thanks for any suggestions that I be offered
I have seen a couple where the rocker doesn't sit quite far enough down on the shoulder of the stud and has a bit of play front to back. It sounds just like the rockers out of adjustment. Give em a wiggle back and forth to check..
good luck
good luck
Hi All
I thought I was the only one that kind of sh*t happened too!!!ROCK ON BIG DADDY!!!!!!!!
Hi All
