sea pump disassembly? >
Old 04-22-2008 | 06:05 AM
Default sea pump disassembly?
Trying to take my sea pump apart to replace seals and bearings. How do I get access to the snap ring? I cant seem to get it apart.
MILD THUNDER is offline
Old 04-22-2008 | 06:16 AM
offthefront's Avatar
you need to press the hub off ....pop out the seal ....then you will have access to the snap ring .... V belt type.....m
offthefront is offline
Old 04-22-2008 | 09:03 AM
You just have to poke and pry that outer seal to get it out. And that's after you press the pulley hub off. Just went through this myself. I ended up sending mine to a pump repair specialist that gets about $80 for the rebuild. Turns out my shaft is bent so they sent it back. $100 for a new shaft = I went a different route.
As you can see in the photo, I had ordered the Merc seals, retaining ring and outer seal and never used them. The bearings are easy to find locally. I'd be happy to part with these parts if you want them.
handfulz28 is offline
Old 04-22-2008 | 07:39 PM
How hard is it to press the pulley mount off? Any tricks?
Handfulz, I would be interested in your parts if i can make them work. THANKS
Old 04-23-2008 | 09:15 AM
I didn't do the work myself, but it should be "as simple as" using a bearing puller in a press to get the pulley mount off. Any decent shop should be able to do it in a matter of minutes? From there you jab away at the front seal until you get it out. I think you then have to press the shaft out the front end of the housing.
My parts should work just fine. It depends on what you find in yours that will determine whether or not you want to rebuild. Good luck, let me know.
BillR
11
07-29-2022 06:31 AM
alecsammy
0
09-21-2008 09:47 AM
HP500Hammer
15
01-30-2008 06:03 PM
fastedy
6
06-05-2007 10:18 PM
Bryan Rose
4
12-29-2006 06:59 AM
