Prop nut size & recommended torque lbs >
Old 04-23-2008 | 07:57 AM
Question Prop nut size & recommended torque lbs
I posted this originally in Prop Talk but have not had a response. Call anyone answer my questions here?
I have an XR drive with sportsmaster lowers. What is the recommened torque lbs for the nut? What size socket will I need for my torque wrench? Thank you!
KS_Jayhawk is offline
Old 04-23-2008 | 01:49 PM
DesertRage's Avatar
My Stock Bravo One takes a 1 1/16" socket. I have never used a torque wrench on it, just a small flex handle breaker bar and snug it up good. I would guess somewhere in the neighborhood of 40-50 foot#'s
DesertRage is offline
Old 04-23-2008 | 01:59 PM
Thanks, I tighten the same way but was not sure if I should use a torque wrench.
Old 04-23-2008 | 02:13 PM
DesertRage's Avatar
I just looked in my manual and it specs 55 foot#'s for a bravo one. As long as it's snug and you use the lock washer with the bendable tangs you should be fine.
Old 04-23-2008 | 03:12 PM
boss252's Avatar
Speed is everything
yep 55 flbs is correct
boss252 is offline
Old 04-23-2008 | 09:14 PM
tblrklakemo's Avatar
SeaRay Sundancer
I always use a torque rench set to 55lbs and then turn what ever more you need to push the tabs down.
And yes, 1 1/16" socket. Helps to have rag or something to hold the prop with when you start crankin on it.
tblrklakemo is offline
Old 04-23-2008 | 09:51 PM
Thanks everyone
KS_Jayhawk
Prop Talk
3
04-25-2008 04:34 PM
ZP'd
3
05-01-2007 06:54 PM
edge_kw
5
08-31-2006 06:23 PM
Zanie
1
09-08-2003 02:16 PM
CAP071
4
04-29-2002 09:26 PM
