my lovley lady muffs
Old 04-24-2008 | 05:31 PM
Default my lovley lady muffs
Hey guys.. can someone give me some instructions on how to safely use the muffs on my inboard..
I don't want to cook anything..
Do I leave it going up to normal operating temperature.
Thanks.
YOLO is offline
Old 04-24-2008 | 10:38 PM
1.Attach muffs
2.Start engine
3.Verify water is coming out exhaust
Do not run engine at high rpms. Mostly idle with maybe a rev or two.
Griff is offline
Old 04-25-2008 | 06:44 AM
SKRAMER's Avatar
Thanks.
Do you have bravo outdrive? or are you a true inboard boat??
SKRAMER is offline
Old 04-25-2008 | 08:12 AM
fund razor's Avatar
http://www.offshoreonly.com/forums/s...59#post2534059 Maybe we can get all of this together in one place.
fund razor is offline
Old 04-25-2008 | 08:14 AM
If it is a true inboard (like a ski boat) the "muffs" look like a plunger with a hose attachment. Put the base around the water pickup, turn on the hose and watch for water out the exhaust. A little tip, dont run the boat in gear out of the water. Saw it done once and roasted a strut bearing.
Tow-N-One is offline
Old 04-25-2008 | 09:59 AM
fund razor's Avatar
From another YOLO post:
"Boat is a 1988 Mirage Intruder 22 ft..
came stock witht he 280 hp 350.. now has a Edelbrock perfomer intake carb spacer and Edelbrock 4 brl.. also has those purple roller lifters and rockers.
Has new paint and thru hull exhaust.. OMC outdrive.. cobra.. New gimble, u joints, impeller and both bellows.."
The dude needs to wrap the muffs around the intakes on his Cobra800 outdrive, turn on the water and start her up. The impellor on his boat is on the backside of the drive, accessable through the plastic cover.
Old 04-25-2008 | 10:04 AM
GLH's Avatar
GLH
Originally Posted by Griff
1.Attach muffs
2.Start engine
You might want to squeez "turn on the water" somewhere in there.
GLH is offline
Old 04-25-2008 | 10:17 AM
X-Rated30's Avatar
I know you are new to the board and everything, but that's just about the GAYEST title for a boat related thread I have ever seen. Not really busting on you, but rather trying to point out that if you want some respect on the board, that IS NOT the way to get it.
X-Rated30 is offline
Old 04-25-2008 | 04:00 PM
r u referring to my boat.. " YOLO" you only live once
my wife didn't like.." no fatties no uglies"..
I was thinking abut LOONATIC... spelling it like the bird..
YOLO is offline
Old 04-25-2008 | 06:01 PM
bouyhunter's Avatar
Apparently you can live more than once on OSO.
What was the screen name before this one?
I don't even remember it at the moment, maybe Fund does.
You layed low for awhile, and I was about to give you a second chance.
Nope, still a tool.
bouyhunter is offline
