pachanga mods >
pachanga mods
pachanga mods
Old 04-25-2008 | 09:39 PM
Default pachanga mods
HELP has anyone tried removing the little ramps on the bottom under the transom of a p22 i have a 383 sb in it and i feel that if i could get the bow up a little higher i could get more top end if i trim out the drive one click the prop bites but anymore than that it blows the prop out of the water top speed GPS is 60 with a 23 cleaver@4800 ihave also tried a 21 cleaver and a 21 mirage
gregg roberts is offline
Old 04-26-2008 | 08:53 AM
Why would you want to remove the pads. That's what my boat rides on
Call Brett at BBLADES and test a Mirage Plus. A 23 is a large prop for a small block. The big block came with at 23 stock.
1BIGJIM is offline
Old 04-30-2008 | 02:04 PM
When at (high) speed the boat doesn't run on the pads so no need to bother.
Alex is offline
Old 04-30-2008 | 07:55 PM
Scarab28's Avatar
Neighbor has the same boat with a 454. He is spining a 21" cleaver at 4900 and is doing 67 mph. Seems if your turning 4800 you should be doing mid sixties.
Scarab28 is offline
Old 05-01-2008 | 02:37 PM
I believe he is talking about the factory trim tabs. The previous owner of my boat took them off and said he gained some speed. I am in the process of putting them back on because I have added more power...hopin I don't have to spring for K-planes!
pachanga is offline
Old 05-01-2008 | 03:48 PM
RBT
Between the first and second set of straked there is a hook built into the boat. The first P22's didn't have them, it was only when they started adding big blocks that they added them, to aid in planing and to stop porposing.
I have a 560hp motor in my P22, it too needs a lot of trim, they are coming off this year..... I just hope there is enough glass!.
RBT is offline
Old 05-01-2008 | 05:47 PM
hoozeyurdaddy's Avatar
how much of a hook is there? there should be more than enough glass there to remove them, you will just have to re-gelcoat it when you get it flat, use a staight edge and don't go to far. but as it was mentioned earlier, it may develope a porpose.
hoozeyurdaddy is offline
Old 05-02-2008 | 09:16 AM
RBT
3/8 if an inch, it is a convex area between the strakes. My motor is lighter than a 350, I will add them back if I have any issues.... but I doubt it.
Then comes the 2" shorty. I should be in the high 80's once done.
Gel is no problem, I wil re-spray it once the bottom is blueprinted.
It already BEATS on all the 22 donzi's... it is fun having a sleeper.
RT
RBT is offline
Old 05-02-2008 | 01:32 PM
bcfountain's Avatar
Registered User
Default pachanga molds
i have heard from the factory that the ramps on the bottom of the hull are for aiding in planning of the boat and to help w/porposing at higher speeds.i have been tempted to grind them off and make the hull stright.i decided not to as i didnot want to mess a good boat up.i am alittle disapointed w/the speed.the boat is a 454,w/a 250tpsblower.on a good day it will run 74 0n gps.i was hoping for more.i bought a 27fever last year,w/502mpi,stock and it will run a solid 70.i think the fountain is a better,faster hull.two diffrent boat designs.good luck w/your pachanga.
bcfountain is offline
Old 05-02-2008 | 01:33 PM
they are built in and as stated before they are not in the water at speed.
Tow-N-One is offline
