5 blade prop guess >
5 blade prop guess
5 blade prop guess
Old 04-30-2008 | 11:42 AM
Velocity Vector's Avatar
Crazy Energy
Default 5 blade prop guess
Someone get me close: W/5 blade
32' Velocity 700Hp Mercury supercat engines X 2, 6000 rpm, xr's 1" shorties. Boat weighs less than 7000#
Velocity Vector is offline
Old 04-30-2008 | 08:46 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile
Do you have a base line set of numbers?
[email protected]
Last edited by bbladesprops; 04-30-2008 at 08:47 PM. Reason: didn't finish the sentence
bbladesprops is offline
Old 04-30-2008 | 10:10 PM
Crazy Energy
Brett, not for the new engines, I had 496 HO'S bravo one 4 blade 15 x 30 pitch, 5000RPM @ 80mph
Old 05-01-2008 | 08:29 AM
KAAMA's Avatar
I have a boat/power very simular to yours....but if your boat were mine, then I would probably try an untouched Hydromotive a 30" or 32" P5X (5-blade) for a baseline start. My disclaimer is that I am not a prop/boat expert, but that is where I would start.
KAAMA is offline
Old 05-01-2008 | 10:41 AM
Beak Boater's Avatar
Charter Member # 545
Had a heavier boat, 38 Fountain, with 600's and shorties, but the revlimiters set at 5300. We ran 32 pitch 5 blade Maximus. With a higher redline, 32's should be a good place to start.
Beak Boater is offline
Old 05-04-2008 | 07:05 PM
Crazy Energy
I found some 15.25 X 33 6 blade herings would this get me close or not at all.
Old 05-05-2008 | 06:26 AM
VV, Keep your money in your pocket until you are ready to run the boat, then call Brett at BBlades and let him send you some demo props. Their demo/trial deal is real reasonable, and you won't end up with a bunch of props that don't work.
RaggedEdge is offline
Old 05-05-2008 | 07:44 AM
Crazy Energy
That's the best advice I have got so far. I did find out from Matt the 33p 6 blade won't work for me.
Old 05-05-2008 | 12:40 PM
Registered User
The chances of you surviving prop testing is pretty minimal
Twin 700 supercat engines in a Velocity? Wow. I had 575 a side in a 30 and got to see God a couple of times. 700's should be unbelievable.
Chris Sunkin is offline
Old 05-05-2008 | 03:01 PM
Crazy Energy
Chris, X-LAX @ WOT
