empty engine bay
Old 05-02-2008 | 07:50 AM
rjr
Default empty engine bay
The motors are coming out of my 382. Clean paint patch, replace some diamond plate. Make sure the starters are good. Anything I am missing? I would hate to think of it after they are back in.
rjr is offline
Old 05-02-2008 | 08:03 AM
Sydwayz's Avatar
Forum Regulator
How many hours on on the boat/power? You may look into replacing the couplers while the motors are out.
Inspect the oil pans and front and rear main seals, as well as the dipstick tube entry into the pan. Check for corrosion/leaks.
Sydwayz is offline
Old 05-02-2008 | 08:56 AM
OldSchool's Avatar
Put new bilge pumps in....it's alot easier now vs. later!!
OldSchool is offline
Old 05-02-2008 | 08:58 AM
Sydwayz's Avatar
Forum Regulator
Good call. Do the Float Switches too.
Make sure you run all of the pigtails as high in the bilge (up the transom) when you connect into the boat's wiring as well. If you make your connections down near the pumps, when your bilge is full of water; all of the connections will just short out if they are under water rather than turn on the pumps and/or trigger the floats.
Ask me how I know that!
Sydwayz is offline
Old 05-02-2008 | 09:37 AM
i did the new style bilge with the float switch built in and they have an output you can put a switch on
wrench_head943 is offline
Old 05-02-2008 | 01:51 PM
rjr
Thanks Guys
rjr is offline
Old 05-02-2008 | 02:34 PM
Gizmo's Avatar
Are we having fun, yet?
Take a good look at the trim/tilt hoses for chaffing. Like Brian said, "Ask me how I know".
Jay
Gizmo is offline
Old 05-02-2008 | 02:50 PM
C_Spray's Avatar
Diamond Member #001
Look here: OSO/Formula/Project....382. I just did EVERYTHING in my 382. I cleaned up the bilge pumps and switches, then installed them with Weatherpack connectors. (Among about a million other projects...)
C_Spray is offline
Old 05-02-2008 | 09:37 PM
Registered User
I'm with sydwayz.... couplers...... along with gimbal bearings, boots and giving the transom units a good going through. Also when you remount the engines use new motor mounts and bolt & spring sets that hold the flywheel housing to the inner transom plate. If its an Alpha replace the aluminum & zinc bolts at the bottom. of the transom units. Think replace anything rubber or wear related. Don't forget to do a proper alignment when you reinstall.
29Firefox is offline
DesertRage
Detailing, Painting, & Fiberglass
2
11-22-2007 12:51 PM
Mark D
Fountain
1
05-04-2004 03:03 PM
Bam Bam
6
04-20-2004 11:44 AM
Shah Mat
2
11-20-2002 12:08 PM
puder
4
03-04-2002 10:32 PM
