To use or not to use >
Old 05-04-2008 | 06:30 PM
Ken N's Avatar
Arrow To use or not to use
Has anyone ever used a MEFI 3 programed for a suppercharger on a stock 502 MPI engine.
Ken N is offline
Old 05-04-2008 | 11:38 PM
hillbilly24's Avatar
No offense but that is a really bad idea. It would probably not casue any damage to the engine but it would run like a$$. If you are just using it as part of a diagnosis process that would be fine but if you are intending to leave installed on the boat it aint gonna work out so well.
hillbilly24 is offline
Old 05-05-2008 | 06:52 AM
Smitty's Avatar
It will need to be reprogrammed for you to use it. My guess is that about the only thing it will do is start and idle. It probably won't rev over 200 rpm because it will be overfueling at that point.
Smitty is offline
Old 05-05-2008 | 06:53 AM
Is your engine supercharged? or is this a ECU you found that has been modified to run on a supersharged motor and yours is NA...
I run one programmed BY Precision marine but I do have a blower on my motor. It runs great!
Bryan Rose is offline
Old 05-05-2008 | 08:52 AM
Ken N's Avatar
Arrow do or not
do or not
My engine is not but the ECU that I got was set for a suppercharger.
Ken N is offline
Old 05-05-2008 | 10:47 AM
Then you need to have it reprogrammed.
Griff is offline
Old 05-05-2008 | 11:02 AM
Elite Marine's Avatar
Sure let us know how it works out!!
All kidding aside, I think the guys have cleared that up for you.
Elite Marine is offline
Old 05-05-2008 | 11:05 AM
Ken N's Avatar
Arrow do or not
Who do you suggest for reprogramming.
Ken N is offline
Old 05-06-2008 | 01:50 AM
I've never had one done myself. Many people have recommend Mark at Precision Marine in the past.
Griff is offline
