Aluminum Oval Port heads >
Old 05-06-2008 | 11:16 AM
Default Aluminum Oval Port heads
Are the GM Aluminum Oval port heads OK for a 454 or 502 Naturally Aspirated?
I have a ZZ502 sitting in my garage, trying to figure what to do with it. I need to work on my 454's in the Chris Cat (hole in piston on one) thinking of putting in 502 long blocks. So I am 1/2 way there in parts (except cam change).
Wannabe
wannabe is offline
Old 05-06-2008 | 11:58 AM
BY U BOY's Avatar
They work great on my 454. I am very happy with the performance thjat i gained with the ZZ502 heads.
BY U BOY is offline
Old 05-07-2008 | 08:01 PM
Wannabe
Here is my email address: [email protected] email me and we can exchange phone numbers. I am in Southgate. About 1 hour from you. I have some experience with the ZZ502 crate motor. Did the same thing as you did. Smoked a 7.4 Merc motor, then pulled them both out and replacing with a pair of ZZ502's.
ROTAX454 is offline
Old 05-07-2008 | 10:39 PM
Rookie's Avatar
Read the past threads on ZZ502's. There is a couple of good ones that explain how to "Marinize" the ZZ502 and about the heads.
Make sure you change the Oil bypass valve.
A friend fried his ZZ cause the oiginal builder and boat owner did not change or block off the original automotive byass.
Rookie is offline
jeff1000man
3
10-30-2007 12:14 PM
danielthelen
12
02-20-2005 02:36 PM
Audiofn
22
11-16-2004 06:19 PM
racinbird
3
06-17-2004 05:38 PM
gofastwannabe
2
09-22-2002 09:10 AM
